Question about Samsung Cell Phones
Oil has entered the phone under the screen cover and i need to find out how to dismantle the phone and clean it out before i restart phone, everything was still working fine when i turned the phone off after it happened mobile phone is a samsung SGH-A801
  • gjblake Mar 07, 2009
    thank you, the hidden screws where the problem
    Sergeant:
  • 320 Answers
Http://www.howdeo.com/learn/how-to/disassemble
click the link directly .
The following link directs you to a service manual that shows you how to disassemble a Samsung D820. Although your model is the D840, the D820 is cosmetically similar and this manual will show you step-by-step how to disassemble the phone (in order to remove the screen). I hope this helps for you. :) Source(s): http://www.scribd.com/doc/264326/Samsung... the model number will be different but the system of disassembling will be same.as you have not mentioned the model number of your phone .but this will solve the screen cleaning problem.
Posted on Mar 07, 2009
  • 10,594 Answers
I can assist you how to open Samsung SGH-A801 phone as ber below mentioned service manual image.
Continue communication is necessary as I will post few images about opening of this phone.
  • Samsung Master
  • 13,433 Answers
Start by taking the covers off the phone, remove the battery and everything else, start unscrewing all the screws you locate, also check under labels and other soft objects for more screws, eventually you will get it apart.
Kitchenaid leaking oil
Remove the chrome drip ring that covers the outer planetary, clean it out, wipe as much oil away as possible, put the drip ring back on and carry on using it. Eventually you will need to completely dismantle the gearbox and clean out & change the grease. It's not the sort of job to look forward to. The old grease slowly breaks down over time and the oil is separating out from the grease solids. It is special food grade grease so completely harmless.
Feb 08, 2014 | KitchenAid 32685 Mixer
The lcd screen cracked and won't show display but touch screen still works and you can turn off and on.
The LCD panel and Touch screen panel were both have separate circuit connection. the covering panel of the LCD is the touch screen the inner is the LCD, replacing an LCD is quite just bit easy all you need a replacement LCD, you can purchased it online or via ebay. and you'll also need a dismantling guide and a very cheap opening tools.
find it here: all mobile phones dismantling guides
Jun 21, 2010 | Samsung SGH-A877 Impression Cell Phone
My 6300 ...suddenly restarts......ie....while m speaking on the phone ...the screen goes white....and then it restarts.... it takes a longer time to switch on..... and sumtimes as soon as it switches...
Well when your phone is working.. just enter the code :*#7370# it will clean up your phone completely..the main cause of this problem is a virus...so just do this and it should be ok.
May 30, 2010 | Nokia 6300 Cellular Phone
How do you clean underneath a blackberry screen?
you need to disassemble the phone .......take off batt cover and unclip the small section at the bottom of the phone ...undo screws in the back under battery cover ...slowly pull the side rails out and remove front cover ...clean and reassemble
May 17, 2010 | RIM Blackberry Curve 8300
Wheres the oil filter on a 1983 Honda XR200R? and how do you clean it?
A 1983 XR200R does not have a replaceable oil filter. It has a cleanable screen. It is located on the left side of the crankcase behind a large nut. I think it is a 17mm. Remove cover and clean screen.
Jan 30, 2010 | 2002 Honda XR 200
Am attempting to restart my '84 Rampage after it was sitting for 10 years. Previously I'd just put in a rebuilt engine and was having a oil puddle developing behind the engine. It, the oil puddle, caught...
If the leak was repaired then no, remember car was sitting so in order for it to leak it would have had to br running, also check all fluids and add fresh gas, may have to drain old gas,i would try to start it first before taking carb apart you may get lucky never know,worst case then take it apart if it doesnt run or start good,well good luck.
Nov 08, 2009 | 1984 Dodge Rampage
How to dismantle the housing of my P910i without damaging it?
On your flip top key pad, you can remove first the middle cover, it is clip type so no need to un scew, but just be very carefull.
after removing it, you'll see to set of screw, remove it so that you can take out the flip key pad,
turn your unit back, near the camera , there are two small cover there , remove it and you will see two screw, take it out
open the battery cover, remove the battery and sim card and the memory card, inside you will see, again two set of screw, take it out,
now all the screw has been removed
on the side oy your unit where you ca find the scroll, try to plip out the cover usig a twizzer or any pointd object, just flip the cover easily until you where able to remove the topcover completely
now just support the LCD, be very carefull so that may never damaged the flex of your screen
at the back of the screen, there are again another set of screw, remove it slowly, make sure that you supported the screen properly
then you can remove the lcd after taking out the stainless cover protection
removing the board is very simple, just lift the board a little higher enough for you to see the back of the board, there is another flex wire attached to the board and the scroll switch, remove it carefully.
then thats it, you had dismantle your unit
Nov 01, 2009 | Sony Ericsson P910i Cellular Phone
Do you have pictures of the parts that need to be removed in order to change the oil pan gasket?
Section 03-01: Engine, 4.6L (4V) 1997 Continental Workshop Manual IN-VEHICLE SERVICE Oil Pan/Oil Pump Screen Cover and Tube Removal
  1. Turn rear suspension leveler compressor switch (5K761) off (located in luggage compartment).
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove oil level dipstick (6750).
  1. Raise vehicle on hoist.
  1. Remove dual converter Y pipe (5F250). Refer to Section 09-00 .
  1. Drain engine oil from crankcase.
  1. Disconnect engine control sensor wiring (12A581) from the low oil level sensor connector.
  1. Remove the power steering pressure hose retainer brackets from the engine front cover studs (two places). Position the power steering pressure hose (3A719) out of the way.
  1. Remove 16 bolts retaining oil pan (6675) to cylinder blocks (6010) and remove oil pan and oil pan gasket (6710).
  1. Remove two bolts retaining oil pump screen cover and tube (6622) to oil pump (6600).
  1. Remove bolt retaining oil pump screen and cover and tube support brace to main bearing stud spacer.
  1. Remove oil pump screen cover and tube. Discard O-ring.
      Item Part Number Description 1 W701240 Bolt (16 Req'd) 2 6675 Oil Pan 3 6622 Oil Pump Screen Cover and Tube 4 6010 Cylinder Blocks 5 6710 Oil Pan Gasket A — Tighten to 20 Nm (14 Lb-Ft), then rotate 60 degrees clockwise
        Installation
        1. Inspect oil pump screen cover and tube and replace if necessary.
        1. Position oil pump screen cover and tube on oil pump with a new O-ring and hand-start two bolts.
        1. Install bolt retaining oil pump screen cover and tube to main bearing stud spacer finger-tight.
        1. Tighten oil pump screen cover and tube-to-oil pump bolts to 8-12 Nm (71-106 lb-in). Tighten oil pump screen cover and tube to main bearing stud spacer bolt to 20-30 Nm (15-22 lb-ft).
        1. Clean oil pan and inspect for damage.
        1. Clean sealing surfaces of engine front cover (6019) and cylinder blocks with a clean cloth. If scraping is required, only use plastic-tipped scrapers to prevent damaging the aluminum sealing surfaces.
        1. Position new oil pan gasket on oil pan.
        1. Apply Silicone Gasket and Sealant F6AZ-19562-AA or equivalent meeting Ford specification WSE-M4G323-A6 where engine front cover meets cylinder blocks and crankshaft rear oil seal retainer meets cylinder blocks. Position oil pan on cylinder blocks and install 16 bolts. Tighten bolts in sequence to 20 Nm (14 lb-ft), then rotate an additional 60 degrees clockwise.
      Apr 03, 2009 | 1997 Lincoln Continental
      Nokia n95 screen doesn't work
      the cover may not be fitted correctly so take it back and have it dismantle and reassemble
      Oct 30, 2008 | Nokia N95 Cellular Phone
      Razr V3i front screen.
      Dear oldgit72
      Use the following guide to take apart the phone's LCD
      http://www.formymobile.co.uk/Dismantle/v3lcd.pdf
      If you need extremely analytical instructions these can be found here.
      http://www.formymobile.co.uk/Dismantle/v3disassembly.pdf
      I hope you can fix your phone.
      Regards
      EngineerGR
      Please dont forget to rate this solution if you found it to be usefull.
      Apr 08, 2008 | Motorola Mobility RAZR V3i Cellular Phone
      Cell Phones Logo
      27 people viewed this question
      Top Samsung Cell Phones Experts
      Computer Repairing
      Computer Repairing
      Ronny Bennett Sr.
      Ronny Bennett Sr.
      Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
