Question about Muratec F-300 Fax
Muratec F-300 is not used for faxing, but will not copy either.
This is a used, but new to my church, copier with no manual. We will not use the fax, only copier. Every time we try to copy, the original does not go through, but a sheet comes out saying there was an 'erase command' and the beep-beep-beep alarm goes off and a light shows us to open the door on the right of the copier. Nothing we have done corrects this. And without a manual, we're at a loss. (I am not able to email from the church where the copier is, so this might prove a bit difficult to diagnose...)
In addition to an online solution, is there a online manual I print?
Thanks.
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    No manual, throw it away
    Genius:
  • 1,218 Answers
Download (FREE) the operators manual from Muratecs web site.
www.muratec.com
Make sure you are in the COPY mode(not FAX.) before trying to make a copy. As the F-300 is a "fax" machine, it will probably be in the fax mode as default.
The downloaded operators manual will help.
Posted on May 28, 2010
Need a copy of the manual for the Toshiba copier #2860 this copier was a gift to my church no manual was with it.
Try the web. Just google the brand and model number and type the particular manual of interest to you (operational or service etc...). You will be directed on what to do further.
Feb 23, 2011 | Toshiba 2860 Copier
The ink cartridge in my Canon MultiPASS F50 ran out. I replaced the cartridge correctly, but now when I try to copy a document using either the laser copier or the fax part of the machine, the papers come...
...I try to copy a document using either the laser copier or the fax part of the machine...
These isnt laser copier, you probably refer to scaner assy... but never mind.. lets solve your problem!
First, new inks are reffiled or original?
Remove inks and look for small hole, ussually on top of crg. and blow in it verry hard.After that from crg. must start to drop ink. Put the ink back in and try to copy/print something.Also run head cleaning for few times.
If now it works that could mean two things:
1) the ink was for long time on warehouse, and nozzles are clodged.
2) your purge unit is faulty and it cant drain ink from crg.Replace purge unit, wich isnt cheap solution.
Or,... buy new LASER Canon multifunctional copier that uses TONER.
Hope that helped!
Aug 09, 2010 | Canon Office Equipment & Supplies
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Just bought a 1515f copier.how do l change copying preferences
Sounds like there is a preset reduction (R/E) programmed??? You can access the manuals here. The answers for your copier question should be in the "copy reference, in the "user tools" section
Manuals are all here:
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
....too many questions to be answered in this forum......but, are you sure that the printer feature is on the machine? Just asking, because it was not standard .
May 07, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Setting date/time stamp for faxes HPC6180
Do you still have the manual that came with the machine? It should have the original setup instructions. I looked on HP's site and couldn't find anything that specifically answered your question, but if you don't have the manual any longer, you can download a copy from HP. It should have what you need:
HP C6180 Manuals
Sep 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Canon PC-6RE Exposure Issue
why certainly, you can either call me and I will walk you through it. the canon pc 6 is a great machine except if you have to change fuser lamp or upper roller. otherwise very reliable call me at 813-323-1410.
Thank You,
Mikey
Apr 03, 2008 | Office Equipment & Supplies
Muratec F-300 Fax Logo
113 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
