I have a Ryobi 18v battery charger (charger no. 1423701) and have blown the internal fuse. The label on the charger indicates the input is 120V AC 60Hz 80 watts and the output is 19V DC 2.2A. What is the replacement fuse required?
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a...
(More)
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a Ryobi 18v battery charger model #1423701.....
One of the front power jacks will not work. The motor side works great. The orthe side the gear on...
(More)
One of the front power jacks will not work. The motor side works great. The orthe side the gear on the shaft from the motor turns and it also turns the gear that raises and lowers the jack but the jack does not move. Are thys a pin that has been sheared and can it be fixed?
