Question about Akai LCT3201AD 32 in. LCD Television
I own an AKIA HDTV Model LCT3201TD and I need an
I own an AKAI HDTV Model LCT3201TD and I need an updated Three Digit Code in order to program my CableVision remote. The codes supplied to me by CableVision do not work, and they suggested I get a complete updated list from you.
Thank you.
  • 583 Answers
Click this link and follow the instructions  step by step to program your remote with exact 3 digit codes,25,0,0,1,0
Posted on Mar 07, 2009
  • 13,433 Answers
Please send the model of your remote thank you.
  • Ekse Mar 07, 2009
    You may try the following codes
    031, 070, 146, 004, 148, 124, 226, 104, 108.
    The model of your remote would be helpful.
  • Ekse Mar 11, 2009
    Hi again.
    HEre is the user manual for your remote
    and above I sent the codes that where on akai here they are again
    if you are unable to open the guide, you are most likely missing a pdf reader, get one for free here
    let me know if you need anything else.
Need to program remote for akai
You want to programme your Akai TV with a universal remote control; I assumes, and posts this solution.
Three digit universal remote codes for Akai TV are:
002/ 0030
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Feb 03, 2012 | Televison & Video
Need a base stand for AKIa LCT3201TD. Is there a part # or way to order one
I have the stand you are looking for. I will sell it to you for 10.00 + shipping. The tv is also available. It has a problem with powering up.
Call me at 314-302-2577.
Jan 02, 2011 | Akai LCT3201TD 32 in. LCD Television
I can not pick up HDTV stations with the proper HDTV antenna. Do I need a converter box?
You do need a converter box with that model. It does not have the HD tuner in it.
Dec 10, 2010 | Akai LCT3201TD 32 in. LCD Television
I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
May 25, 2009 | Akai LCT3201TD 32 in. LCD Television
Black screen has sound akia lct 3201td
hi you must contact akai and let them know your problem if you had your tv less than a year than you are covered
Jan 10, 2009 | Akai LCT3201TD 32 in. LCD Television
Cannot program remote for tv
Here are the codes from Visio's tech support line:
These are listed in order of probability and are for remotes using four digit codes. Call them if you need a three or five digit code.
Good Luck
Jan 03, 2009 | Vizio L32 32 in. LCD HDTV
Remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Nov 22, 2008 | Akai LCT3215/26 32 in. LCD Television
Remote code for Akai 37" lcd with Dish Network
I have a akai 42" plasma and went to walmart and bought a Phillips Universal remote SRU3004WM/17 for @$14.95 and it works both my Akai and Dish network.......
Jul 17, 2008 | Akai LCT3201TD 32 in. LCD Television
Borken remote; universal remote doesn't work!
I have had on order since December 2007 the Akai replacement remote #WIR3500001-EQ01 the Akai TV/DVD combo model #CFTD2011. I called each month for 5 months, being told each time that it was on backorder. A few days ago, I received a letter in the mail stating that this remote is no longer made and is not available.
I too have tried universal remotes without any luck. If anyone has a resolution, it would be greatly appreciated.
Nov 19, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai LCT3201AD 32 in. LCD Television Logo
267 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
