Vizio GV47LFhdtv, Power on no anything xcept controll buttons light but won,t respond. Shuts down in a few minutes. HELP!!!
I have same problem, did you find out anything?
Posted on May 17, 2010
Our dryer does not function after a slight power outage due to an electrical storm. The number 88 blinks for a minute then goes to 18 . There is no response to the control panel , no buttons work!
brand and model numbers would be very helpful. without this info, I would try unplugging, wait about a minute, then plug back in. sometimes units can be reset by just cycling the power. Good luck.
Aug 05, 2017 | Dryers
How can I fix a Vizio TV that turns itself off every 7 Minutes?
Check whether the timer is set to that shutdown time 7 minutes.
May 21, 2016 | Vizio Televison & Video
My Vizio xvt3d554sv TV has no sound, what can I do?
-Main Board requires replace
-go to www.shopjimmy.com to look up part and verify your panel part number
-Cost is $169.19 but is out of stock at this time
-website is setup to send alerts when part becomes available
-Gils Electronics..Hilo, Hawaii
Jul 09, 2015 | Vizio XVT3D554SV 3D LCD TV
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Error 5100 when I try to print anything . bought it few hours ago can any body help?
hi try this 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal..
Jun 09, 2009 | Canon PIXMA iP1300 Printer
Vizio 42" plasma tv model#p42hdtv10a
yes,veryry possible you have a bad transister on the power supply board .best way to fix it is to change the hole board.
Oct 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Televison & Video Logo
    391 people viewed this question
    Top Televison & Video Experts
