Question about Epson Stylus C84 InkJet Printer
New ink in printer but will not put ink on paper.
The printer had been hooked up to my computer but had not been used for a couple of months. Installed new ink and ran a nozzel clean, but no ink will go onto the paper. The computers shows that there is ink and that it should be printing but no ink is put on the paper although the paper runs through like it should.
  • roofing657 Mar 17, 2009
    My problem is similar in that the printer goes through the motions of printing, but there is nothing on the paper. However, it has only been about two weeks since the printer was used. I tried to find the rubber cup mentioned in Solution #1, but I don't see it. Please know that I am non-techie. Is there any hope for me?
  • 353 Answers
It sounds like blocked nozzles to me, providing you're SURE you have good cartridges, properly installed (you did take the yellow plastic tapes off the vents before you installed the cartridges of course).
You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results
Posted on Mar 09, 2009
Alignment failed
It sounds like your print cartridge is not releasing any ink. Recommend you start with replacing that. It could be due to the ink jet being dried over or clogged.
Sep 12, 2013 | HP Photosmart A636 Compact Photo Printer
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
Has been setting 6 months , has new ink and paper
Ink jet printers are meant to be used regularly, at least once a week.
If it was used before you put it away for 6 months, the ink is dry on the jets.
First try the cleaning function. If you're lucky, after 2 or 3 tries it may work again, and the more you use it the better print quality will result.
Failing that, there are cleaning kits you can purchase.
They consist of a cleaning solution you can inject into a used-up cartridge.
Or better yet, you can take it to one of the places where they refill ink, and for a fee they'll get it going for you.
Apr 18, 2010 | Epson Stylus C88 InkJet Photo Printer
Prints nothing on paper. checked ink cartridges
please the your pc in add a printer and again install a printer driver
and you go control panelt and select the printer an dchous this printer
and restart your pc and try printing giveup page
Sep 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
After being abroad for 3 months i can home to find printer not printing correctly i replaced the 5 ink cartridges but only 2 working Black and cyan
The ink has dried in the print head. If the print head comes out, remove it and apply rubbing alcohol or water with a paper towel to the nozels to disolve the ink. Once the ink seems to be fluid, replace the print head and ink cartridges, do a head cleaning and try printing again.
If the print head cannot be removed, get a childs medicine syringe, draw in some rubbing alcohol. Remove the non printing carts and apply a couple of small drops of alcohol to each ink port on the print head. apply some more drops to the ink port of the carts and replace and try a head cleaning and print.
If this does not work, continue to ask for help. The aim is to save the print head, not buy a new printer.
May 29, 2009 | Brother DCP 115C All-In-One InkJet Printer
Epson RX-500 ink's full but won't print
u just have to replace the refilled cartridges.and insert new orignal cartridges.this is a very common problem in epson printers that refilled cartridges work sometimes and sometimes dont.so insert new orignal cartridges to have good printouts.
Sep 09, 2008 | Epson Stylus RX580 InkJet Photo Printer
COLOR NOT VIVID
The DeskJet 940c is not really the highest quality printer out there on the market. However, having said that, the printer is still capable of producing decent quality printouts. You might play with your printer settings for print intensity, lightness, ink volume.
May 10, 2008 | HP DeskJet 940c InkJet Printer
Black and yellow ink not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 18, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Wants to print but won't put ink on paper
I'm experiencing the same problem. I tried to troubleshoot through software that came with printer, but no luck. Here's what happens:
The printer worked great for a month or so. Then, I didn't use it for a few months. When I tried to use it again, it acts like it's printing. My computer shows it's printing, the printer runs through all the steps, including moving the print cartridges back and forth over the paper as it should, but no ink comes out on paper.
Any suggestions?
Nov 05, 2007 | Lexmark X1270 All-In-One InkJet Printer
Epson Stylus CX4600 printer/scanner
It sounds like the nozzles may be blocked, if it has been left for 10 months will no ink - It will have dried up. It is probably worth you running a head cleaning procedure which can be done using the Epson software. Please let us know if this helps. Thanks Daniel
Mar 13, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus C84 InkJet Printer Logo
152 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
