Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
I have an Hitachi 42edt41a and I have a one and a half inch black line going vertically from top to bottom. I can't get rid of it. help
  • calabres331 Mar 14, 2009
    Black Line Vertical going down middle of screen!
    I have the same problem!
    Also sometimes a black square. These issues come and go as the TV runs longer, so is it heat related? Is the lamp/bulb dying?
    Scholar:
  • 73 Answers
Calabras, you are right it is heat related but there is no bulb or lamp in this set. There is a design flaw that causes this. There are several threads in this section that detail precise fixing instructions.
Here's a link to forum that shows what you need to do to repair the tv. This is a very inexpensive fix but is a bit time consuming and requires a lot of common sense. http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed-2.html
The dismantle is not the same but soldering the chips on the orange ribbons is exactly what you need to do. So pay attention to that part of the tutorial.
Posted on Mar 23, 2009
Have red vertical lines in center of screen from top to bottom
iam also facing same problum,that problum wont start immedietly,when we r watching after 1 hr it will start
Oct 21, 2012 | Hitachi 42HDS69 42 in. Plasma Television
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Jun 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi 42EDT41A Turn On with white and yellow vertical lines
you have to replace the vertical sweep IC and check the voltage across its VCC. If you cant understand tech words, better visit the service center.
Jul 07, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
42edt41a
Several runs had bad display panels, but other failures can cause a shutdown condition. There is a fuse in the power supply that must be removed in order to determine the failure by checking voltage at the fuse socket. I suggest you find a local authorized Hitachi servicer to continue. This is not a simple fix.
Oct 27, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
451 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
