Question about Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA
THE GREEEN LIGHT COMES ON BUT NOT THE COMPRESSER AND IT IS NOT CO
IT DEFROSTED ALL BY ITSELF AND I CLEANED THE WATER OUT, BUT IT THE COMPRESSER NEVER STARTED UP AGAIN, AND THE GREEN LIGHT STILL COMES ON. CAN YOU PLEASE TELL ME WHAT TO DO?
  • Haier Master
  • 8,220 Answers
Bypass the cold control and see if it comes on. If it does then change the cold control if it dont then examine the compressor relay and see if it is burned up. If the compressor relay ain't it then you have a bad compressor.
Posted on Mar 07, 2009
Why are the sides of my upright freezer hot and the compressor very hot
Good Afternoon Friend,
I understand the sides of your Frigidaire freezer are hot and the compressor is very hot. I also see that the drain plug was frozen and the coils had lots of frost, which you defrosted and your freezer began running again. It looks like your freezer quit again and started up, leaving everything hot. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing your appliance to be hot. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire Freezers
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
I have this majic chef freezer about 7 cubic ft. 3 years old turned it off to defrost and when turning it back on it won't get cold?? Compresser is hot so I believe it is working and lights on in front...
I'd let it dry out totally then try it again, some of the electronics may have gotten wet when you defrosted it. Give it a week somewhere warm and dry like a garage. If you didn't attack built up ice in the freezer with a knife while defrosting it it should work after it dries out. Most people end up killing freezers by accidently poking holes in the evap coil while trying to remove built up ice.
Aug 14, 2011 | Magic Chef Chest Freezer MCCF5WBX
My freezer N308 F&P makes a little noise but motor not going. It is slowly starting to defrost and water coming out...I turned it off and on but same.
The compressor could be gone, the niose you hear will be the internal fan unit running , this circulates the cold air arount the inside of the unit. If this unit has a timer, it will be a located in the compressor housing well in the lower rear of the , it will be separate from the compressor and will have 5 wires plugged into it, on that unit, locate a small round knob and turn it clockwise, it should start, if it does, replace the timer, if not, check the thermostat. This may need a tech to do safely as you are working with a live curcuit.
Hope that helps but without being there it quite hard to explain.
Dont forget to vote and goodluck, need more help contact me wgheaven@yahoo.com.au and if you are in Perth Australia, I can have a look at it.
Mar 22, 2011 | Freezers
Not freezing on top shelf of door
try to replace the Styrofoam cup then put on the top.. if the same happens.or it will be frozen it means styrofaom is .................................. then use another...
Jun 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a hotpoint freezer 8742 and the red light came on and it defrosted. how do i get the light to go off and start freezing again
if turning the power off for a short while doesn't work then the unit will need a technicians eye. I would expect it's a thermocouple or thermo switch, but worst case it could be that it's lost gas pressure
Jan 19, 2010 | Freezers
Red light on not green ...has to be green to freeze up again
Try to unplug it for about 5 minutes, and then plug it back in
Apr 17, 2009 | Freezers
Green light
could be a possible short in the electrical
Jan 19, 2008 | Danby 5.5 cu. ft. / 156 liter Chest...
Frigidaire upright not cooling
It sound like you had a freon leak, you REALLY need to get this checked by a tech. if you are leaking freon it can be dangerous.
Jul 31, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA Logo
284 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
