Question about Kenmore Ovens
Self cleanning oven - door is lock and I can not get it to open
The stove Lock - therefore the stove door will not open this is a Kenmore stove
If you open the lid on your stove,you will probably be able to reset the
switch manually (the latch).with the lid up its located toward the front
behind the safety latch.(by no means attempt to force,bypass,or disable this
switch)this is a safety feature designed to protect you from the high temps
generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Try this, and let me know if it worked, I am trying to help someone else with the same problem, that stove is Model, 790
Posted on Mar 07, 2009
  • jwhite9137 Mar 07, 2009
    I got this information on a previous question, on FixYa, just so you know its not something I know by experience.
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door will not open after self clean
There are two easy things to try to fix this.
First, unplug the oven, or turn off the circuit breaker to it - so long as power is cut to the oven. Leave it for about 5 minutes, then plug it back in or turn the circuit breaker back on and try to open the door.
If that doesn't work, turn on the self-cleaning cycle again, and let it run for about 15 minutes. Then turn it off and wait another 15 minutes, and see if the door will open.
If neither of those work, you have a more serious problem with the locking mechanism. Either a bad solenoid or a damaged heat locking mechanism. Both of these will require removing the stove top to access and repair. Let me know if the above suggestions fix the problem. If they don't, I will get you more specifics on repairing the locking mechanism - assuming you're up for that.
-Dyllan
Mar 06, 2008 | Ovens
I Have A self cleaning stove Kenmore.When i want to clean and lock the door it will not start the cycle it shows door.?
There is a bad connection on the door lock to the sensor that detects whether the door is closed. Usually this means the door lock is broken, repairclinic.com will have a replacement if you find that this is the case. Let me know what you find.
Benjamin
Nov 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
224 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
