Uverse vibration/noise problem
Since my uverse high speed internet and video system was installed I have a persistent low decibel humming/vibration noise throughout the house. Thought originally this was outside my house due to a heat pump or generator, but cannot find a source. Do you have others who have this problem? Is this the cause, and if so what is the solution?
pierre1811
  • 144 Answers
SOURCE: Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Posted on Jan 22, 2009
AegisKay
  • 51 Answers
SOURCE: Loud humming noise coming from 360
The loud humming noise is usually the DVD drive. It is very fast but is very loud. If you have the NXE dashboard you can download games to you Xbox 360 to run them from the hard drive (you will still need to put in the disk for copy protection issues). The Xbox should make less noise then. Try to mount the Xbox 360 on a hard surface which is in contact with a soft floor to reduce the noise travelling through your home.
If it is making a loud noise while there is no disk in the drive then take the console to a Microsoft dealer whenever you can to have them take a look at it.
Posted on Feb 13, 2009
SOURCE: Pump will not work in high speed
Clean the relay contacts on the board. Cut the power, ofcourse. Also, try switching the hot wire on the low side of the pump to the high side to rule out the pump.
Posted on Jun 08, 2009
muralme
  • 20 Answers
SOURCE: I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Posted on Jul 12, 2009
  • 114 Answers
SOURCE: My front end makes a loud humming noise.
Alignment will not create a sound by it's self. The most common cause of humming (especially if you have an agressive tread design)is a wear pattern in the tires...check for that or rotate the tires around & see if the noise changes. If it does then you know it's in the tires. & Not always, but most of the time a bearing noise will increase or decrease in intensity if you load up one side at a time by doing 35-50 mph & turning slightly to each side.
Posted on Sep 30, 2009
4x4. What causes humming sound?
The used tires may be unevenly worn.
Jan 26, 2016 | 2007 Ford Explorer Sport Trac
Mitsubishi Pajero2.5 ltr engine model 4D56, year build 1992. Engine runs like hum noise, after replacing the timinh belts.
Missmatched belt teeth or grooves. Wrong belt for the car installed. Worn waterpump, or bearings for cam.
Dec 13, 2013 | Cars & Trucks
Haier A/C CPR10XC7-L
The Haier ESA410J-L is part of the air conditioner test program at Consumer Reports. In our lab tests, air conditioner models like the ESA410J-L are rated on multiple criteria, such as those listed below.
Comfort:This is how well temperature and humidity are controlled at the low-cool setting. The best performers held temperatures to within one-and-a-half degrees of the setpoint.
Indoor noise low:This judgment of indoor noise at the low-cool setting combines an objective measurement of noise level using a decibel meter with a subjective assessment of noise quality (how annoying or grating the particular sounds were).
Indoor noise high:This judgment of indoor noise at the high-cool setting combines an objective measurement of noise level using a decibel meter with a subjective assessment of noise quality (how annoying or grating the particular sounds were).
Jul 22, 2012 | Televison & Video
Vibration at highway speeds loud humming noise,
Possibly a wheel bearing issue, does it `get progressively worse as speed increases or better as it decreases? does it stop when applying the brakes or get worse?
Oct 30, 2011 | 2006 Ford Escape
2004 ford freestar 4.2L engine...high pitched
this sounds odd but mine did this when i replaced the wipers. it seems the design of the wiper frame was making a whistle at higher speeds. the freestar wipers are exposed on the window cowl and not hidden so they endure the winds at high speed. it is worth a shot.
Apr 27, 2010 | 2004 Ford Freestar
2004 Chrysler Crossfire 25,000 mls auto, road hum noise
MOST of the hums after a while come from the diff as the back axle does the driving and almost all its life runs the same way except when going in reverse ,is the rear diff meshing and worn on both the crownwheel and the pinion and the humming gets slightly louder the faster you go and almost goes when almost stopped and this can also be the slight vibration you get so get the diff oil drained and refilled and check if there is any metal in the oil when drained if so thats your problem But it will last for years like that..Let me know how you get on RON
Oct 23, 2009 | 2004 Chrysler Crossfire
Loud hum/vibration on acceleration - Saab 95 Linear 2.3t
I have the exact same issue. I can't seem to replicate it for the dealer and it is identical to what you are describing. PLEASE e-mail me if you figure it out or know anything. I want to get it fixed and it to go away! Thanks! Todd. Tm2200@aol.com
Jul 18, 2009 | Saab 9 5 Cars & Trucks
I replaced the brakes all around on my wifes pontiac torrent, she complained of a vibration in the pedal, now with new rotors and drums at high speeds especially when brakeing down hill there is a hum and...
Absolutely; wasn't positive until you mentioned the 'hum'. Bad bearings first warning sign is usually the humming noise before the vibration but since you have both, I'd be shocked if it weren't the bearinig, especially since you've got new rotors. In the past, a badly turned or warped rotor would mimic a bad bearing. Best of luck.
Greg
Jun 14, 2009 | 2007 Pontiac Torrent AWD
Hampton bay fan noise
The fan does not need to be oiled. The bearings are what manufacturers described as "permanently-sealed", which means that they're designed such that they don't require oiling. The manufacturers recommend against oiling, and if you really wanted to do it, you'd have to be an expert, because there is some very complex disassembly to be done, which requires specialized tools.
HOWEVER...
The problem is not related to oil. A lack of oil does not produce a hum. If a fan's bearings are low on oil, the sound generated is a scraping or brushing sound. A hum, on the other hand, is an electrical sound. All fan motors hum to some degree -- the cheap made-in-China ones, like in your Hampton Bay fan, hum more than others. There are some steps you can take to reduce the hum:
* If you are using the fan with a solid-state control (i.e. a dimmer), that will cause the fan to hum. These controls are dangerous when used with fans, and a fire can result. You should have a qualified person remove the switch immediately and replace it with either a regular on/off switch OR a discrete-speed (i.e. 3-speed or 4-speed, rather than variable-dimmer) switch. Specially-designed ceiling fan switches such as this are available at your local Home Depot or Lowes. You could also use a remote-control system.
* If you have a remote control or other speed control system, make sure that the pull-chain speed control on the fan is set to the "high" position (highest speed possible) and left there.
* Make sure that all the screws are tight -- this includes screws which hold up the fan's mounting bracket, hold the blades onto the fan, and hold any applicable glass onto the light kit.
* Even if you don't have a speed control, the motor will still produce an electrical hum -- and the blades, which are physically attached to the motor, serve as mechanical amplifiers -- they take the tiny electrical hum and amplify it just like the big brass funnel speaker on an antique gramophone (record player) takes the tiny vibrations of the needle on the record and amplifies them to a comfortably audible level. High-end fans have a rubber flywheel attached to the motor between the blade holders and the motor unit -- and since rubber doesn't transmit vibrations well, this effectively deadens the sound. Your fan doesn't have one of these, but you can effectively replicate the noise-dampening effect by putting rubber washers between where the blade holders touch the bottom of the motor AND between where the screws which hold the blade holders onto the motor, meet the blade holders themselves. This will completely remove the path along which the sound vibrations can flow to the blades, and thus your hum will stop.
I hope this helps you! If you have any other questions, or need clarification, please ask!
Jun 14, 2008 | Hampton Bay 24002 Ceiling Fan
Celing fan making noise, how to oil
HOWEVER...
Apr 30, 2008 | Hampton Bay 24002 Ceiling Fan
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
