Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
How to replace chain, oilier tube in mcculloch FR 2.0 ?
2 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: need to replace chain on 450s mcculloch chain saw
You might want to purchase a combination set with a new bar and chain, if so, Oregon #108764 is the 16" length set.
If you only want either a chain or bar, then the following are the correct ones for your chainsaw:
Chain 16" @ 3/8" pitch = #91VX054G (low profile, semi-chisel)
Bar 16" = Oregon #160SDEA318 (w adjustable chain tensioner)
Bar 16" = Oregon #160SDET318 (no adjustable bar slot for use on chainsaw originally equipped with the Intenz bar only)
Hope you find this very helpful and best regards!
Posted on Aug 19, 2009
dontbother10
  • 2220 Answers
SOURCE: I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Posted on Oct 08, 2009
I have a McCulloch 2618 cav chain saw and the chain adjusting screw has broken. How do i replace it.
[PDF]IPL, McCulloch, Mac 2618 CAV, 952802079, 2008-05, Chain Saw www.mcculloch.com/ddoc/MCCI/MCCI2008.../MCCI2008_AAaa__545014313.pdf
  1. Cached
  2. Similar
CHAIN SAW MODEL(s). 545014313. Mac2618CAV. DATE. 3/04/08. Replaces. PARTS LIST. 545014313 -- 5/31/07. Ref. Part No. Description. Ref. Part No.
McCulloch MAC2618CAV - Chainsaws
www.mcculloch.com > McCulloch International > X-ref > Chainsaws > McCulloch
  1. Cached
  2. Similar
Newsroom · Parts & Accessories · Chainsaw parts & ... MAC2618CAV. Select model, 006 · 050 · 10 ... McCulloch MAC2618CAV ' Bar Length - 18 inch/45cm ...
McCulloch MAC 2618 CAV (952802079) Chainsaw Spares & Parts ...
www.ransomspares.co.uk > Parts > Garden Spares > Chainsaws > McCulloch
  1. Cached
  2. Similar
Buy genuine replacement McCulloch Chainsaw MAC 2618 CAV (952802079) spares from an authorised supplier. Price match promise and next day delivery.
McCulloch Chainsaw Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/chainsawpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch chainsaw model below to find OEM part numbers. ... McCulloch MAC 2618CAV Chainsaw Type 1 and 2
McCulloch Trimmer Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/trimmerpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch trimmer model below to find OEM part numbers.
Mac 2618CAV - McCulloch Spares, Parts & Accessories
www.4mcculloch.co.uk > Chainsaws McCulloch Mac 2618CAV SGO002 Spark Plug. Genuine spare part. Suitable for: McCulloch Mac 2618CAV. Type: SGO002 Commonly used in small handheld ...
McCulloch Mac 2618CAV Chainsaws Chain ' BuySpares
https://www.buyspares.co.uk > Chainsaw > McCulloch > Mac 2618CAV
  1. Cached
Buy your McCulloch Mac 2618CAV chainsaw Chain at BuySpares - choose from an extensive range of McCulloch chainsaw parts and McCulloch accessories. McCulloch 2618 Google Search
Nov 29, 2016 | McCulloch Garden
Mcculloch chain saw fr 2.0
http://www.ktoutdoor.com/mcculloch_parts_page.htm
Here you go.
Sep 28, 2015 | McCulloch Garden
BAR OILER NOT WORKING GEARS OK .WILL THE TANK PLUG UP . HUSKY 340
Hello slehman629,
Take off the chain and bar and you can clean out the oilier tube with a piece of wire or a dull drill bit a small screw might work.It is just saw dust that gets packed in there. Thank you for using fix ya.
May 11, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Attempting to replace fuel filter on a MCC1635AK Chain Saw. Lifting the filter out of the tank with bent wire per the manual, I came up with the end of a tube. The filter is still there, and fastened,...
The second tube in the tank is just a return from the primer, there should be nothing on the end, and it does not attach to anything, just replace the filter on the end of the fuel hose, and leave the other hose alone.
Feb 13, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mcculloch start with choke will run when choke in will not run when use throttle wont pick up
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 21, 2009 | McCulloch Garden
When I top up the chain oil it runs out of the opposite side really rapidly, I don't see how to fill it in the instruction booklet
Are you using bar oil? Is it less than 2 years old (warranted)? Did the chain come off and hit the tank?
I think your saw may have been impacted and the oil tank is broken. I didn't see an oil vent on the IPL but if the filler is on the bottom of the saw and you must lay it on its side to fill there must be one. Take it and your bar oil with you and stop by your friendly neighborhood Husky dealer. Ask what they think the problem might be. You might be pleasantly surprised. Purchase some 2 cycle oil, a new chain, some bar oil, something. When time for a new saw remember how they treated you.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Oct 15, 2009 | Husqvarna Forest & Garden No.967012396 345...
My husqavara saw wont oil tthe chain .. what should i do
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
McCulloch Pro Mac 610 replacement chain
The McCulloch ProMac 600 series (610/650) doesn't recommend a saw chain replacement part because you can get differently-sized bars for it. This one came with a 20" bar.
According to an Amazon.com search tonight, the Oregon company makes a replacement part stock number D70. I have got an Oregon H78 replacement chain at my hardware store and it's a hair too small. Not all 20" saw chains are created equal!!
Dec 07, 2008 | Oregon Scientific Oregon S54 Replacement...
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
272 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
Roland W VanLue
Roland W VanLue
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
