Question about Water Heaters
My Rinnai R94 LSi stops sending hot water intermittently, resumes after a few minutes, no error message. Could it be water savers are reducing flow below the minimum necessary for the demand sensor? If so, must I conclude that what the Rinnai gains in gas savings over a tank, we sort of lose in wasted water if the savers are removed, or in the inconvenience of disappearing hot water if we keepo them? Or could the problem be elsewhere? I have the Rinnai set to 120 degrees, the minimum it heats to, on the theory that this maximizes hot water demand, but the problem still occurs esp. for spouse who cuts the 120-degree water with some cold water for showers (even 120 is too hot for her). I've got the shower head apart and am playing with removal of various washers. The water pressure out the headless shower pipe is not super great, but all the piping is new. Advice?
  • 234 Answers
II would think that the unit is going out on hil imit because there is not enough psi on the water coming in.Is this unit on well water or city?If it on well water you have run some cleaner in it every six months.L on the side of the heat or inside and there a toll free number to call talk to a tech.
Posted on Mar 15, 2009
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
Lound vibration when running
Check gas control valve.
Good luck,
Feb 18, 2013 | Rinnai Water Heaters
Have a Rannai R75LS and getting hot water everywhere except my sink in the bathroom. System doesn't come on with only bathroom sink running.
I think these have a water pressure s/w or water movement s/w id replace the aerator 1st to a non water saver one or if possible remove water flow reducer looks like a metal washer .. if this not help you may need to replace the pressure s/ tank..
May 01, 2011 | Rinnai Water Heaters
I have a Rinnai model R53-i-1. When hot is called for, heater turns on and produces a low to loud vibrating noise. It seems to change with water flow use at tap. I called Rinnai, got the name of local guy,...
A low to loud vibrating noise is an indication of an Air /Fuel imbalance . When you flow more water , does the noise become louder ? if so , have a service technician check for pproper incoming gas supply . The requirements are located on the left hand side of the Rinnai unit . There will be a minimum/maximum specification.
Another issue could be the burners being "dirty" and needing to be cleaned .
Also investigate the venting and make sure all joints are sealed properly and the venting is sloped correctly . If you have your installation manual , please refer to the venting section in regards to usage of a condensate collector . This can be a cause of noise .
There is a clear vinyl hose running from the bottom of the heat exchanger to the front of the gas valve . Please inspect this hose for any moisture or signs of staining . This can lead to issues with the gas valve . It must be determined where the moisture is coming from (See previous comment about Condensate collector !) .
The cold water solenoid valve usually has nothing to do with this type of noise .
As far as yourself being able to repair the unit ? I have no idea of your experience but a qualified licensed service technician should be used as this is a gas fired appliance and as such is subject to huge liabilities when being repaired .
Have them call Rinnai Tech Support while on site for any assistance needed.
You shouldn't have to "put upo " with any noise issues . The Rinnai ujnits run at 49 decibals (about the same level as a conversation .
Good Luck !
Jan 30, 2011 | Rinnai Water Heaters
I have a problem with my Rinnai hot water heater giving me intermitant hot and cold. The water gets hot and I get in the shower. A few minutes later the hot water stops and I have to shut of the hot water...
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Solution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably mechanically inclined:
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem.
May 24, 2010 | Rinnai Webstone The isolator EXP tankless...
Runs out of hot water
I wonder if you have this problem below caused by a drop in water pressure from someone flushing a toilet or a washing machine. I would call the company to remedy this issue.
17. What is a cold water sandwich effect? The term “cold water sandwich effect” is a term that is used to describe the introduction of cold water into the hot water supply line during frequent on/off operation of an instantaneous water heater. The cold water sandwich effect, when present, appears as a momentary drop in hot water temperature as it is discharged from a hot water supply outlet (i.e. shower, tub, or faucet). This phenomenon is present in the operation of all instantaneous, tankless style, water heaters, but is minimized with the high tech design of Rinnai water heaters.
The technology built into the Rinnai water heaters is designed to minimize the cold water sandwich effect. Rinnai water heaters are microprocessor controlled and when water flow through them ceases, they remain in a “ready to fire state” for approximately 1 minute. If water flow through a Rinnai water heater begins within the first minute following water flow stoppage, the water heater will fire back up within 1 to 2 seconds. This minimizes the cold water sandwich effect that would otherwise be experienced with a low tech tankless water heater. It should be noted that the cold water sandwich effect cannot be removed completely from tankless style water heaters. The safety standards developed to insure the safe operation of water heaters require a delay in the ignition sequence of all gas water heaters.
While the cold water sandwich effect cannot be completely eliminated from standard plumbing systems, it can be eliminated from plumbing systems that have a supply and return hot water circulating system. Rinnai has developed 2 methods to eliminate the cold water sandwich effect in residential hot water circulating systems.
The first (and preferred) method to remove the cold water sandwich from circulating systems utilizes a small electric tank water heater (powered up) that is used with a dual purpose. The small water heater acts as a mixing tank to eliminate the cold water sandwich effect from the Rinnai water heater and it uses its electric heating element to offset the heat losses from the hot water circulating system.
The second method to remove the cold water sandwich from circulating systems utilizes a small 2 to 6 gallon storage tank installed on the hot water outlet of the Rinnai water heater. This tank acts as a mixing tank to blend the cold water sandwich with hot water and eliminating its effect at fixtures.
Mar 11, 2009 | Rinnai Water Heaters
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Rinnai R94-LSi keeps turning off and beeps and blinks 12
Here is the link for the service codes for this unit. they will help you solve the problem. Good Luck
Jan 07, 2009 | Water Heaters
Hooking up Tandem Rinnai R94 LSi
you will find a master controler at a electrical lighting and hardware store you have to be specific with the model and voltage/amprage rating. they will give you a schematic with the controler. .............please rate this ........thanks
Aug 30, 2008 | Water Heaters
Water Heaters Logo
435 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
