Question about GE 30 in. Gas Self Clean Slide-In Range with Sealed Burners Kitchen Range
Large Flames from oven
We have a GE Model JGBP31WEH3WW and it was given to us. It is not very old, matter of fact it looks new. However, when I turn on the oven flames come up out of the heat vents from the bottom. Is this because they never converted it from natural to LP or do we need to replace a part.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Converted Gas to Propane
Mister, read this post http://www.fixya.com/support/t127727-kenmore_gas_range_oven_not_working Catriver
Posted on Jan 16, 2007
jsrock516
  • 5911 Answers
SOURCE: Flames in oven are WAY too high! Having trouble lowering them.
Did you change the orifice in the regulator? The orifice opening for LP is a different diameter than the opening for Natural Gas. If you've already attempted changing the settings from Natural to LP, you may want to double check the orifice under the regulator cap, or...you may have a regulator problem. You will need to turn the gas off prior to attempting this. The regulator will be located in the back of the oven somewhere near where the gas line connects to the stove. There is a gas orifice that needs to be turned over to change gas settings. "LP" should be present if it is set correctly. Let me know if this helps.
Posted on Jul 30, 2007
Amigaman
  • 248 Answers
SOURCE: lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Posted on Nov 19, 2007
SOURCE: changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Posted on Nov 22, 2007
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
GE Electric Range (2001 JCP67YWW) has a mind of its own
I suggest you look up the model number and see if it has a replaceable thermostat for the oven and try that. Make sure you disconnect the stove from the power outlet first.
Dec 11, 2013 | GE Kitchen Ranges
Ge gas range oven burner flames perfect, broiler flames rolling & orange
Anytime the flames on a burner aren't blue or "perfect" as you say... it means that there is an improper mixture of gas to air ratio... this is usually caused by either and obstruction..such as spider etc or grease... and is almost always the problem is located at the venture which is where air and the gas come together...try blowing that burner out real good with compressed air.
OR the same problem in mixture happens when the burner is wore out..corrosion causing the holes to enlarge or close up... in that case you need a new burner.
So I would "clean the fire out of it" and check for obstructions and corrosion
Hope this helps
Jun 22, 2012 | GE Kitchen Ranges
My 10 year old whirlpool super capacity 456's right front control knob started to burn with flames shooting out. Disconnected plug from wall and have been using lighter to start burners. Any idea as
there's a wiring harness with 4 or sometimes 5 switches depending on the model you have that slides onto the valve so when you turn the knob that burner will light,the switch most likely shorted out.if this is a regular stove with an oven and burners on top look down at the bottom,under the oven door you'll see a draw,open the draw and look on the frame not on the draw on the frame and you'll find a tag with the model and serial number on it,send the model number and i can look up your model.
Nov 20, 2011 | Kitchen Ranges
Ordered and received a SW Valve Service 270 using my GE oven's model number - PGB910SEM1SS. I received part no. WB24K10023. It fixed the problems I had - gas smell before the oven would light, and b
Hello Mike,
Firstly i have come up with a totally different part number for that model number i found the part number to be WB19K10043 i used a couple different part's lookup sites and all had the same part number so i do believe that part number ya have is incorrect .
Secondly it could be adjusted if it looks like the one in the picture below,to adjust it ya would turn the piece i circled in red in a clockwise direction. But look into getting the correct part number for that model number before trying to adjust it
GENE
Oct 31, 2011 | Kitchen Ranges
GE Spectra Oven flames TOO High
have your gas pressure regulator checked
Nov 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Sep 10, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Lp flames to top of oven
Nov 18, 2007 | Kitchen Ranges
Oven GE GAS Model JGSP44AEV3AA will not light
Once the ignitor starts to glow the oven should light within 20-30 seconds. If it doesn't then the ignitor is too weak and needs to be replaced. These are usually easy to replace by taking it loose and splicing in the new one. You can view a diagram, price, and part # at http://www3.sears.com/. You will need the entire model # from the sticker on the oven to look it up. On alot of models you can pull out the bottom drawer and disconnect the ignitor wiring and pull it out from inside the oven. Then just install the new one in the reverse order. This is the most common repair for ovens more than 3 yrs. old. Also, if the ignitor looks whitish instead of charcoal color this is a good indication that it needs to be replaced. Hope this helps.
Nov 03, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
