Question about Maytag MDG6000 Dryer
Won't stay lit
Dryer starts,igniter lites,gas fires stays on a few seconds then shuts off.
  • lugnut93308 Mar 07, 2009
    Sir,I won't be able to find out until monday,parts houses are all closed for today.Thank you for the information,that's what I thought,but really didn't know for sure.
  • Maytag Master
  • 8,220 Answers
You ignitor is working and sensor is working because it will fire up. so those pesky coils are intermittant because they get hot and quit cool off and work some more . replace them
Won't stay lit - cc8e664.jpgHere is a little ditty I wrote some time ago about this subject
INTERMITTANT COILS
Posted on Mar 07, 2009
    Sniper:
  • 58 Answers
I had this same problem and it was the hot surface ignitor. It got hot enough to light the gas but not hot enough to satisfy the flame rectifier. It would light the gas then go out. This was soon after changing the coils on the gas valve. If it doesn't glow almost white hot the gas won't stay on.
Posted on Jun 06, 2009
Have Maytag gas dryer model DG412. Ignited glows, will light gas, but then gas shuts off after a minute or so. Replaced the solenoids, didn't help, same thing happens. Gas ignites, but quickly shuts off....
if the flame goes out fast like that the dryer has to be cleaned out and also check the vent line,all a dryer does is move air if it's blocked and can't move air the flame won't stay lit.that's a gas dryer it should be taken apart once a year and cleaned so this doesn't happen and also so you don't have a fire.check the duct where the lint filter slides into and you can remove the vent line from the back of the dryer,if the gas stays on then you know the block is in the vent line.make sure there isn't a cage outside or a birds nest isn't in the vent these are common things that happen.
Nov 12, 2017 | Maytag Dryers
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Atwood motorhome furnace won't stay lit
I would say this is your electronic ignition system but it sounds like it is not getting gas. This is why they do a 3 time try and shut off. Check you supply line right down to the regulator. Hose could have got partially kinked along the line as well.
Jan 31, 2013 | Heating & Cooling
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
Gas dryer not heating properly
This sounds like the flame sensor is bad to me.
If it does not work properly, the unit will shut off for safety. The machine assumes that the burner did not light and rather than run gas into your house, it shuts off. It may try to start a certain number of times and then shut off.
You may be able to remove and clean it (flame sensor) lightly with a scotch brite pad and it may work properly again.
Otherwise it will need replacement.
This is a very common problem and the part is probably in stock.
Post a comment on your progress as this solution is likely to be useful to many people.
Thanks,
Tim
The problem is not the gas valve.
May 06, 2009 | Whirlpool LGR5636L Gas Dryer
Flame goes out after 5 seconds
the thermocupple is a small tube that when heated shrinks to let gas flow if it is no good gas will not flow change the thermocupple thank you for useing fixya please rate me
Feb 24, 2009 | Dryers
Dryers Logo
379 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
