Question about Samsung Blackjack SGH-I607 Smartphone
My Black Jack II ring tone files are corrupted and will not play
When I try to change the ring tone on my phone, I get the error message:
Alert
This ring tone file is corrupted or unavailable. Please choose a different ring tone.
I haven't changed anything on my phone and the only tone that will play is the AT&T tone. ALL of the files are supposedly corrupted and will not play, even the tones that came with my phone. What should I do to fix this?
  • Anonymous May 13, 2009
    i am having the same exact problem! did u get your fixed?? help someone!!
  • Anonymous May 20, 2009
    I have the exact same problem and it's really annoying. My phone won't even play my videos or anything.
Check out this thread. near the bottom is an explanation to reset your phone back to default settings. you will lose all programs d/l so I suggest you sync your phone with your comp to save all your contacts first.
http://forums.wireless.att.com/cng/board/message?board.id=samsung&thread.id=68502
Posted on May 27, 2009
No message alert tone on Gt-s7562 samsung mobile phone
go to message from the home screen or application list. then go to message settings---> notification---> change the type of alert tone you desired. . viola............
Nov 30, 2012 | Samsung Cell Phones
No ringing tone while getting call from somebody also when I goto setting to change ring tone I can not play any of tones and I ca not close the window as well and I have to restart manually .
Possible that there are errors in your software. so remove the battery and memory card. scan your memory card for virus or corrupt files. If not format the card.Now reset and start the phone , if there is no change in your tone settings, the the software needs to be reinstalled.
Please make sure that a recently downloaded music file or ring-tone has caused this breakdown , if so remove the file and try once again.
Jan 22, 2011 | Cell Phones
My message alert tone that is set in my profile does not play upon receiving a message... is my software corrupted? or am i just having an error with my theme?
Hi there
First check to see if your phone is not on silent, and also check your spund settings to see if your ringtone isnt switched on,also set your phone to vibrate and ring option..
if the issue persists pls try using the original theme of the phone and test it with a message..
if this works then you should change the theme,but if the problem persists.then the ringer of your phone is faulty and it should be replaced..
Jul 14, 2010 | Nokia 6300 Cellular Phone
Samsung SPH-i325 Ringing Tone problem
It's possible that there's something wrong with your microphone of phone,just change a new one to try it
Jul 08, 2010 | Samsung Ace SPH-i325
There are no sounds played back
maybe the file format is not mp3
Sep 03, 2009 | Cell Phones
Ring Tones for test messages
You can change the text message alert tones but you have to do it by accessing the phone's file system via a data cable connected to your computer. Goto lg-vu.com and search for text alerts and you'll find detailed instructions on how to do it.
Apr 21, 2009 | LG Vu CU920 Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
I would like to change text message ring tone but can only find how to change ringtone and not for text messages
I found the answer!! Go to Menu>Settings>Profiles, then go to Options>Edit. Push the right side of the square (that you use to navigate the menus) so that you're working with New Messages, not Incoming Call. Go down to Message Alert Tone, then go to Options>Change>Use Effect Tone. If you were trying to use an .mmf that you downloaded, or any of the preloaded ones that can be used as incoming call ringtones, you'd go to Use My Alert Tone here. There are 4 tones under Use Effect Tone, and you can play them and choose one, just like you do to play and choose your ringtone.
Jul 23, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Set a ringtone for a text message SYNC SGH-A707
"My Effect Tones" can only be MMF files. Ringtones can be WAV, MMF, MP3, etc... as long as the file is under 300kb I think. You need to convert your ring tones to MMF to use them as "Text Tones"
Jun 08, 2008 | Samsung SYNC SGH-A707 Cellular Phone
How do you change ringtones/settings !?
Well firstly,..make sure you have downloaded some songs via Bluetooth to the Sd card.
Then select setup.
then go to Ringer alert Style.
Then click edit.
then ringtone line 1,..click on the lil blue/white file folder.
A screen should come up saying select ring tone,..scroll down to more,..and click more
click my audio
click my audio again, scroll down to trans flash,..which is where any bluetooth downloaded ringtones, songs, go too.
select what you want from your downloads, click insert
then click save.
You can also do that for mesages
Hope it helps
jodee
Dec 08, 2007 | Motorola Mobility MING A1200
Samsung Blackjack SGH-I607 Smartphone Logo
749 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
