Mitsubishi TV 1992 LOSS of Vertical Hold... Can I fix at home? The picturae is incredible I hope I can fix it without paying a $$$$$$ Thanks,
  • aocfausett Mar 07, 2009
    I need to know HOW to repair it or if too difficult and must call a repairman to my home?
    Shoule this cost a fortune??? I NN to know some perameters of cost for this.
    are you in the chandler az area?
  • 19,396 Answers
Call a repair person and have it fixed at home for about $200, the repair of vertical deflection faults cannot be done by the home user.
Posted on Mar 09, 2009
  • 154 Answers
There is a problem on the main board. so its a time to call a repair man... aprox.$$100
Posted on Mar 07, 2009
    Top Expert:
  • Televison & ... Master
  • 77,169 Answers
The average cost of repair for issues like this is about $400-600, why because Mitsubishi charges an arm and a leg for parts, also they only sell complete circuit boards, get a new LCD HDTV, u will be amazed at the picture.
  • yadayada
    yadayada Mar 09, 2009
    is who in the AZ area???
    President:
  • 948 Answers
Unless you are a TV repair person you can't fix it yourself. Expect about $150 plus parts if you call the repair person to your home.
    Brigadier General:
  • 8,619 Answers
Hi
You need to replace the vertical Ic on the main board.
  • Rylee Smith
    Rylee Smith Mar 07, 2009
    First try to adjust the Vertical Hold by :
    1. TV turned on
    2. Press 'Menu' then '2' then '3' then '5' then '7'.(or 1,2,5,7)
    NEVER SELECT ANY RESET:Doing so will erase all Data and ruin your week!
    3. Press 'Audio' for the category.
    4. Press 'Adjust up and down' to change the data.
    5. Press 'Enter' to save the data when finished.
    6. When you have made all the adjustments you want press 'Menu' twice.
    There may be a loss of the synch pulse coming off the separator circuit which pulls it off the pedestal signal from the cable company. Sometimes the cable company has a weak vertical synch pulse and the set can't quite lock in on it. So, you may want to check with the cable company as well.If not, then the issue is with the Vertical Circuit and you will need a service tech who can look at it.
    Please revert for any clarifications.
    Thanks
    Rylee
    Sergeant:
    Novelist:
  • 277 Answers
The vertical ic number i343 is faulty needs replacement,
Continuous vertical roll on tv
Wow 5 months without a solution. NOT GOOD.. Well I hope I can help...
This sounds like a vertical hold problem, and is normally easy to fix.... There should be a couple of nob's on the lower back of the TV. One for vertical and one for Horizontal hold. You need to find the vertical hold nob and adjust it, until the rolling stops and stabilizes. If however these nob's are not visible you will have to take TV to an engineer to fix it.
Hope this helps..
Nov 11, 2010 | Zenith B27A11Z 27" TV
Nn reputable repairman in Chandler AZ. just moved here.
BASED ON THE AGE OF YOUR TV,GO TO WALMART AND BUY A NEW ONE.YOU PAY ONE THIRD THE PRICE AS OPPOSED TO THE PRICE OF FIXING THIS ONE.
Mar 07, 2009 | Televison & Video
Mitsubishi vs-50609 wont stay powered on
Hello carriegomez,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 05, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Power loss reset the timer.
Good Day, Nyung; First try ro reset TV, unplug TV from the wall for 3 - 4 minutes then plug back into wall ac outlet; 2. This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. I hope this was helpful, big IRISH.
Apr 10, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Vertical hold on tv
no control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
Apr 07, 2008 | Audiovox AVT-1475 13" TV
Vertical hold adjustment
Loss of vertical sync or any other problem with your Mits is
likely caused by bad power supply capacitors....they are made by Rubicon and are notorious "leakers"......very tedious and
expensive to fix...................good set back in the day.......T.
Mar 10, 2008 | Televison & Video
Vertical hold not working
on mitsubishi just replace the caps that are near the vertical ic this will fix the problem good luck
Nov 02, 2007 | Mitsubishi WT-46805 46" Rear Projection...
No power
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) Hope this helps you!
Sep 14, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
