Question about HP OfficeJet 6110 All-In-One InkJet Printer
I am not sure what device I need to hook up the printer to my com
Haven't used the printer in awhile and missing the cord to hook the printer to my laptop. what would it look like, would it be like a phone cord. I have one cord that is like a phone one but when I try and hook it up it states no connection and I need to scan. Suggestions
  • 1,602 Answers
ONE END OF THE CABLE WILL HAVE A USB CONNECTOR ON IT AND THE OTHER END WILL HAVE A SQAURE BOX HOSE LOOK TO IT, LENGTH WILLNOT MATTER MOST OF THE TIME IT IS 2,4,6,8,10,12 FEET LONG AND ANY LONGER THAN THAT YOU WOULD NEED A REPEEDER IN THE MIDDLE SO YOU WOULDNT LOOSE THE SIGNAL.
RODGANDYSR
Posted on Mar 07, 2009
  • 64 Answers
Hi, for this model you will want to use a USB cable, it will most likely have a square connector on one end (connects to the printer) and a rectangle connector on the other end (connects to the computer) the phone jack looking thing if for an ethernet cable so you can use it as a network printer.
What cord does this take mine is missing and how do I hook it up? Wireless or hard wire?
You need to give us what make and model of your macine is friend.
Ask again with that information and we will help you.
Sep 14, 2014 | Office Equipment & Supplies
Printer won't turn off
Check the power supply cords; make sure they are attached properly. If you are using a power strip, surge protector or any other device where the power supply cord is not plugged directly into a wall outlet, bypass them and plug the printer into a wall outlet; see if that changes anything.
If that doesn't work, remove the printer's power cord from the outlet and all the other cables that the printer connects to the computer to.
Wait 5 or 10 minutes for the printer's CMOS and RAM chips to power off completely.
After enough time has elapsed, plug only the printer's power cord into the wall outlet (do not hook up any of the communication cables in e.g. USB, or serial cables, or network cables.)
Then press the power "on" button.
If the error message is gone, power off the printer.
Uninstall the printer and all its programs from the computer.
Do a clean install and follow the procedures of hooking up the printer as though you are installing it for the very 1st time.
You may have to obtain firmware and/or software updates from HP on your specific printer.
You may also have to check with your OS vendor to make sure you have all the updates/service packs on your PC or laptop
Nov 23, 2013 | HP Photosmart C7280 Printer
Our remote went missing so I'm trying to use the other remote that came with the projector. This remote is model number RM-PJ2. Should I be able to click and move forward with the slides on Power...
Make sure the USB cable is run from the projector to the computer. You might also want to open device manager (right click my computer>properties>hardware>device manager) and make sure the projector does not have a yellow triangle with an ! on it. You can also try unhooking the USB cord, deleting the projector from device manager, then hooking the USB cord in again to reinstall the drivers. It should all be stock drivers, so you shouldn't need to download anything extra. Also be sure that the batteries in the remote are good and working. Sometimes you can point an infrared remote at a digital camera and see the light on it (I've never gotten it to work though) to verify that it's working.
Jun 16, 2011 | Sony VPL CX4 Multimedia Projector
I have brought the printer with me to use in our 5th wheel- I am trying to hook up- I have 2 cords- beige cord for printer to computer- power cord -3 round openings- where do I plug in??? There is an open...
I believe you're missing the power supply for the printer. The 3-prong power cord plugs in to the power supply. If you lost that part of the printer, I can only advise you to call Lexmark. They might be able to send you one.
Apr 05, 2010 | Lexmark X5470 All-In-One InkJet Printer
Where does the printer hook up to the computer
You will need to purchase a printer USB cable for this printer. They are relatively inexpensive and can be found at any store with an electronics department. I feel your pain on this issue as I find it very annoying that these peices are extra.
The flat rectangular USB end plugs into an available USB slot on your computer while the more square end plugs into the back of the printer.
Click HERE for an example of what you need.
Hope this helps!
Mar 08, 2010 | HP Photosmart C8180 InkJet Printer
Printer does not print
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 29, 2008 | HP Officejet 7130 All-In-One InkJet...
Printer not able to hook up to new Dell
your printer the g85 on the backyou will see below yhr bar codes where the power cord is four connections. looking at it from the back facing you on the far right is the power cord next to the power cord is the cord from the top lid second from the left i dont use this but i think it is the serial connection and far left connection is the usb cable the usb is the best on to use the two phone lines on what i call the leg or base far left remmber they need a special phone cord most cords only have two wires hooked up this on needs all four or it just want work right.hoop this helps
Jun 01, 2008 | HP G85xi All-Color InkJet Printer
Not sure how to connect power cord,
Here is the link to dell download manual page for your printer. You will need usb cable to connect to pc and power cable
link
http://support.dell.com/support/edocs/systems/a940/
cheers
Feb 19, 2008 | Dell A940 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
