Question about Sharp R-1405 / R-140 Microwave Oven
Sharp R-1490 microwave 2000
All buttons, lights, fan & carousel work but no heat
  • davidlaine Apr 25, 2009
    I have an LG Microwave and all buttons, lights, fan & carousel work but will not heat up>
  • 3 Answers
The fuse to the magnetron may be blown or the mag it's self is gone. if the door switch was bad the unit wouldn't rotate the carousel. if it is the fuse (check with a multi-meter and check continuity across both side of the fuse, acheap one will do) if it is good, time to replace the micro, as they are cheap and repair would cost more than to replace. hope this helps.
bf
Posted on Mar 07, 2009
Sharp r-930ak microwave stopped working
either the high voltage side has gone done or pcb is not putting out the output.
Sep 14, 2009 | Sharp R-930AK Convection/Microwave Oven
Sharp carousel microwave model # 508ak has power but does not heat food when you press the start button. thanks in advance!
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
Jul 11, 2009 | Sharp R-510HW Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
May 12, 2009 | Microwave Ovens
Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
I don't hear the fan, the carousel doesn't spin, nothing works but touchpad & light
It sounds like you may have an intermittent door switch or loose door switch mount.
Does it work differently when you wiggle the door?
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 19, 2007 | Sharp R-408HS Microwave Oven
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Sharp R-1405 / R-140 Microwave Oven Logo
297 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
