Question about Goodman CLJ30AR32 Air Conditioner
What causes the pulse control on the ac circuit board to fail?
The power indicator on the air-conditioner lights up when switched on, but when the pulse is applied on the ac control board the ac fails to start.
  • mark milligan
    mark milligan May 11, 2010
    where s this pulse control?
  • 478 Answers
First check your breakers they are seprerate than the indoor they are in the distibution panel and or next to the out door unit. If still no...then check the control wiring (two or more wires in a cable) going to the outdoor unit the supply the voltage to the contactor which is the swich inside the control panel it can be manually pressed in to checked mechanically with the power off, or electically with the power on. It does have high enough to hurt you, so unless you are comfortable with it you may need a tech.
Posted on Mar 25, 2009
What can cause air conditioner fan to not work?
split systems
the inside fan works all the time when on so that the room air is circulated past the thermostat
the outside fan only works when the compressor is working to cool the condenser coils
with the inside fan not working it indicates a power board failure , power failure or control panel problem
if it is a window (box ) ac then it will be the power board problem
in either case it is a job for a ac technician as it could be just a start/run capacitor fault.
Jul 09, 2015 | Heating & Cooling
No power
you have a low amp fuse protecting transformer. could be thermostat issues.
Dec 12, 2013 | Ruud Rheem Corsaire Control Circuit Board...
No lights on AC unit but fan is running.
Possible that the processor has failed and it seems to give a through circuit to the fan which runs when power is switched on.
You can check the voltage on the processor IC and if absent then you must check the DC voltage on the circuit board. If there is no power then it is the failure of the power supply section and if not the processor is the suspect.
Sep 27, 2013 | Fedders Heating & Cooling
Air conditioner unit on the wall not working, and the remnote does not turn it on, the indicator lights are not lit either.
Please check teh power to the wall unit first, then if this is present check the remote control, check the battery. Point the remote to your phone camera and see if the camera detects the IR emission. If so the remote is working and the power supply has failed on the AC unit.
Open to check on the main power circuit , the program controller circuit.
Jun 17, 2011 | Heating & Cooling
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
No power on the ac switch board
Hi, If there is no power in switch board you need to observe upstream line of power including your switch board, cables, circuit breaker supplying your air conditioner. You may find poor connection, defective switch / breaker. This task can be easy by using voltage meter and test pen. Regards,
Dec 07, 2010 | Carrier 52PQ307 Wall/Window Air...
Cannot turn on.
Since you have power to the clock display- there is power to the unit. The "power" function button has failed because the momentary switch on the circuit board below the touch pad has failed. These little push switches have a short service life.
I suggest checking a source who sells the control circuit board for Soleus Air LX-140. Might be similiar component.
KT
Jul 30, 2010 | Soleus LX-120 Air Conditioner
Blinking light
Switch OFF the circuit breaker of ac, after 5 sec, switch ON the circuit breaker and re-start the ac. If this will appear again, check the wiring connection and PCB of your ac.
Jul 25, 2010 | Carrier 36KCARMS Air Conditioner
My carrier A/C turns off by itself but the light blinks
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
Jun 17, 2009 | Carrier 36KCARMS Air Conditioner
Unit will not turn on
I have two of these units (actually it is my sister and brother in law's) but they come to me to fix stuff.
Last year they came to me with this unit not working. No indication of power on the display. I diagnosed it down to the PWB Assmebly, Main. I believe they are referring to it as a Power printed circuit board (part #6871A20271A). The new board worked for about 4 months and then quit in the same manner. Also, the second unit quit in the same manner also indicating the circuit board is bad.
I don't want to throw a board at it till I know why they are burning out. Also, want to try to diagnose the board to component level ($33.28/board last year). Let me know if this helps if you have the same symptoms?
You can replace the board but my experience says it will only last for a short time till we find the real cause (Sears must know this problem exist).
Apr 21, 2009 | Kenmore 76129 Air Conditioner
Goodman CLJ30AR32 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
