Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a Maytag Gemini double oven with a gas
Maytag Gemini gas stove...how far above the gas burner may a vented microwave oven be installed? I have a Maytag Gemini double oven with a gas range and would like to know how many inches above the gas burners may a vented microwave oven be installed?
  • Anonymous Mar 17, 2014
    how to set time bake on maytag gemini range
    President:
  • 1,865 Answers
18" is standard
Posted on Apr 16, 2009
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
reviews.us-appliance.com/.../MET8776BS-Maytag-Gemini-Smoothtop-D...
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Oct 16, 2015 | Maytag Kitchen Ranges
I have a Maytag Gemini double oven and the right rear burner ignites but wont shut off?
Great move, you kept your domicile from exploding. It sounds like a bad valve but I am only guesing.
Nov 27, 2014 | Maytag Gemini 30" Self-Cleaning...
I smell gas faintly when I walk by my gas range
If it uses gas pilot lights, check each of them to make sure they are lit. If this is not the problem, then check the fittings on the gas supply to the stove - almost every time I've run into a slow leak it's been from a union coupling. It's also possible a valve for one of the burners is not shutting off properly (although I've never run into that before). In this case, I expect the gas odor would be strongest at one of the burners.
Dec 05, 2010 | Maytag Gemini 30" Self-Cleaning...
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Has anyone else had a serious problem with the electrical wiring in their Maytag Gemini Gas Range? Without using the stove, the ignitors started firing and then stopped when I turned all the burners on....
Same problem here - and I have read about others with this problem. Usually blamed on moisture getting into the control unit ( which is under the backmost burner knob). I did not have a spill on the cooktop, nor was I "over zealous" cleaning. Looks like a bad design. Waiting to hear from the technician how much THIS is going to cost me...
Jan 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Bottom oven does not heat
i ceertainly think that there is problem with the burner. as per the working principle of an Oven the ignitor is doin its job so the problem is with the burner please do check it out...
Nov 25, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Mounting a microwave above stove
A copy of the installation instructions for your units should contain how far it should be.Try to study it. You'll likely find that the over the range units will fit the standard 30" cabinet and also provide the required clearance to the range top. Consider the following:- power source (dedicated circuit, with an outlet box in the cabinet above). Venting (outside ot inside), and attaching method. Though they're simple in concept to install, it's a bit awkward in reality. The main thing you need to determine is sufficient space between the MW and the stove. You will have to check, but I believe you need 18" beneath the microwave. Many companies have brackets for that purpose.
Jul 15, 2008 | Frigidaire FGB24S5A Gas Single Oven
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
1,106 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
