Question about LG DLE2514 Electric Dryer
Inside dryer silver flaking off
Lg dryer DLE2514W - inside of dryer the silver coating is flaking off or can be scratched off.
  • 5 Answers
If you need a new drum. Follow the instructions below.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Posted on Apr 02, 2009
    New Friend:
Thanks for the writeup! Did you notice the new drum was a bit harder to turn than the old one? By hand it was pretty tough, but seems to run okay.
Posted on Apr 13, 2014
    Scholar:
  • 86 Answers
Your find that this inner drum needs replacing! It could be done under the warranty if its under a year old or the product has been recalled for this problem before. If not then you will be buy a new inner drum yourself.
Posted on Mar 07, 2009
  • Kris Seymour Mar 07, 2009
Where can you buy a fuse for LD trom dryer model DLE2514W
Check for parts here:
https://www.repairclinic.com/Shop-For-Parts/a8b200d684324/Model-DLE2514W-LG-Dryer-Parts
Jan 15, 2018 | Dryers
LG DLE 2514W DRYER MAKES RUMBLING NOISE WHILE RUNNING
Hi Willie Bolden
Sounds like your problem is drum rollers are in need of lubrication or replacement.
Go to the following webpage for a schematic of your dryer and parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/parts-for-lg-dle2514w-abweeus.html
Oct 11, 2012 | LG DLE2514 Electric Dryer
Paint colour for 1973 tx750 yamaha
Can duplicate the 73 paint but it is gold candy over silver metal flake.
  1. apply Grey primer sealer
  2. apply silver base coat, apply 3 coats
  3. apply silver metal flake mixed with clear, about 3 coats
  4. apply about 2 coats heavy clear
  5. sand clear smooth because metal flake makes it rough
  6. apply about 3 coats of tinted clear (candy gold or yellow)
  7. let it dry, inspect it, wet sand with 600 or finer
  8. apply final coats of clear to all parts except the fuel tank, apply only one coat to tank
  9. lightly wet sand the tank
  10. paint the gold and black striping on the tank, don't have any stickers and paint is thinner
  11. apply 3 medium coats of clear to the tank
  12. west sand with 1200 grit and polish all parts
  13. mix huge glass of good tequila, get lawn chair, sit back and admire
hope this helps
John
May 23, 2011 | Yamaha TX 750 Motorcycles
My lg DLE2514W Dryer has a pice of felt that keeps the front of the drum from rubbing. this is comming undone. how do i replace this?
I have provided you a link to a repair website that has an excellence article on how to access the inside of this dryer.
http://www.appliancerepairlesson.com/2011/01/12/how-to-access-lg-dryer-dryer-breakdown/
Mar 01, 2011 | LG DLE2514 Electric Dryer
Whirlpool gold GT4175SPS-2 inside door paint is flaking and revealing metal. Is it safe to use?
Scratches, flaking and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord first.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 09, 2010 | Microwave Ovens
LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
Jan 12, 2010 | LG DLE2514 Electric Dryer
My DLE2514W LG dryer keeps running with 6 Min. Left
There is a humidity sensor (Hence the words Sensor Dry) inside the machine which trips out when it sees a lack of moisture in the air going past it.
It is not adjustable without special equipment
That sensor has failed and will need replaceing
Jun 07, 2009 | LG DLE2514 Electric Dryer
LG TROMM DRYER DLE2514W
Hello Napew65,
Please use this link http://136.166.4.200/contents/Laundry/DLE2514W.htm to get access to the service, operator and all manuals associated with your dryer. You can run diagnostics as shown in the service manual to interpret the root cause of your problem. Let me know if you still aren't able to get this resolved.
Regards
Rick
Jan 04, 2009 | LG DLE2514 Electric Dryer
LG DLE2514 Electric Dryer Logo
150 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
