Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
How to wire a Coleman proprane furnace
I have a coleman model number 4312K729 and serial number 0984087C. We have a blue, white and red coming out of the furnace to a plug. Coming outside of the plug white to a yellow blue to blue and red to red. How do i hook this up to a 12volt.
  • Farley Redfield
    Farley Redfield May 11, 2010
    I assume this is heating only no AC?
Do anyone know anything about a coleman furnace modle number 9210
Posted on Jul 20, 2009
I just bought a houseboat with the same furnace in it.  I will check it this weekend and provide you with the wiring directions should you still need them.
Posted on May 20, 2009
  • TomSmal May 25, 2009
    The red wire is +12V, the blue wire is ground (0V), and the white/yellow is the thermostat input.  A power switch is placed between the +12V input and the red wire (furncae on with the switch closed, furnace off with it open).  The thermostat connects the yellow wire to ground (blue wire) when heat is called for.
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Electric furnace coleman model # 3120A751. It won't shut off on its own. Just keeps blowing hot air any ideas?
something is wrong in the 24v. make sure no wires touching each other both behind the tstat and on the circuit board in the furnace.
and obviously r to red w to white y to yellow.....
Jan 27, 2015 | Coleman Heating & Cooling
Hook ignition wire
This is a typical 5 wire setup. The colors can change depending on the person installing the system, meaning if the installer liked using BLUE for cooling instead of YELLOW, that's how he hooked them up. If YELLOW wasn't available, they could of used BLUE or BLACK, and visa-versa. But, the wiring below is the most common. If you have a heat pump system, it will be slightly different. Hope this helps!
R- Red- Power 24v
G- Green- Fan
W- White- Heat
Y- Yellow- Cooling
C- Blue- Common
Dec 07, 2013 | Coleman Heating & Cooling
Coleman evcon wrong polarity or twinning error what does this code mean
It will probably means you have your hot and neutral wires crossed. The furnace has 120 volts coming in to it from your house. If the hot and neutral wire are wired to the furnace wrong, it will show this error. Take the electrical box loose where you can see the power cord coming in to the furnace. (turn off the circuit breaker to the furnace) Take the white and black wire loose , connect the black where the white wire was and the white where the black was. All you are doing is reversing polarity. I hope this works for you.
Apr 18, 2011 | Coleman Heating & Cooling
My coleman gas furnace wont ignite. i replaced the ingintor but i think a wire has crossed and i am not sure which wire. i purchased my furnace and it didnt come with an owners manual
If you have the model number, go to the Coleman Heating and Cooling website and using the model number, you can search for and download the Owners Manual.
Mar 11, 2011 | Coleman Heating & Cooling
How old is my Coleman Evcon Furnace, Modle Number: DGAT056BDE? I can't seem to find a Manufacturing date sticker. It was claimed to only be a year old, now living here a year it would now be 2 years old. ...
The Serial Number would really help in defining how old your Coleman furnace is. The model you have is used predominantly in manufactured housing. To find the Serial Number, you will need to remove the upper shroud of the furnace. There should be a sticker or plate on the back of that shroud of just inside the housing of the furnace, that will give you the Model # & Serial #. Armed with that, you can do a little detective work, as to it's age.
Mar 03, 2011 | Coleman Heating & Cooling
New Furnace Coleman Model 8623A Ser#037873318
Red wire to R. There may be a R, Rc, Rh, You will have either one or 2 of these. They shaould be jumped together with a small jumper from the factory. Then white to W, green to G and yellow to Y
Mar 20, 2010 | Coleman Heating & Cooling
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
Coleman furnace problem
Sometimes people replace the blower motors with a higher horse power. Has this motor ever been changed? I believe the original should be a GE motor
Nov 12, 2007 | Heating & Cooling
Heating & Cooling Logo
529 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
