Question about Frymaster Dean 2424G Deep Fryer
Honeywell propane relay won't start
This is for my boiler.
The relay would not kick in, though there was a buzzing noise. So I slapped the relay a little and nothing happened. I turned the dial from "on" to "pilot" and the pilot flame went out. I cannot get the pilot flame to come back on, now.
With the dial set to "pilot" I can push in the red button and light the pilot. When I let go of the red button the pilot goes out. I cannot turn the dial to "on" with the button pushed in, and so cannot get the pilot to stay on without holding in the button.
When the thermostat is up high, so the boiler wants to boil, I can hear buzzing. I can slap the relay a little and hear clicking. However, with the pilot out, it obviously will not kick in.
Do I need to replace the relay? Should I take it off and clean it or look for burn spots?
  • 30 Answers
For the pilot you have to hold the red button down for about a minute or two while it is lit, then turning it to on. If you tried this and it still wont stay lit then you can try replacing the thermocouple. For the relay the best way to tell is take voltage reading to see if the coil is getting voltage across it.relays are usually inexpensive,and easy to install.Just be sure to turn the power off befor touching the wires,and mark them so you know which wire goes to what terminal.
Posted on Mar 08, 2009
2007 Yamaha Crux ticking noise when cold
Hi, Imran I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Cam Chains---CLICKIT
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fronk Forks---Plunk
9. Fuel pumps---WHIRR
10. Gears---WHINE
11. Head Gasket---HISS
12. Hydraulic Lifters---TAP
13. Instrument Clusters---BUZZING
14. Kick Starter---GRINDS
15. Pistons---SLAP
16. Radiators---GURGLE
17. Rear Chains---RATTLE
18. Rear Shocks---SQUEAK
19. Relays---CLICK&BUZZ
20. Shaft Drives---WHIRR
21. Shifting Trans---CLUNK
22. Solid Lifters---TICK
23. Speedometers---bzzz
24. Starters---CLICK
26. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Valve Train Noise at Startup then goes away
Weird engine noise on cold start and ticking cct
YAMAHA LIBERO G5 CRUX COMPLETE WORKSHOP REPAIR MANUAL 2005 2008 Download... $20
https://www.partsfish.com/page/oem-parts-for-yamaha
YAMAHA Crux Owner Manual
Nov 03, 2017 | 2007 Yamaha Crux
Armstrong ultra advantage 93, propane. blower kicks on right away when i call for heat via thermostat. will not ignite. blower keeps running. fan set to auto. help!
Make sure that there is not a manual limit that has tripped and needs to be reset. Roll out limits, and check primary limit. On some models if a limit is tripped the blower starts to run right away.
I don't know if this will fix it. But that is where I would start if I was working on this problem. Then I would check if the combustion blower starts and then if it makes the pressure switch. Then check if the ignitor is sparking or glowing and getting power to it. A good volt meter will help in checking.
Good Luck.
Oct 26, 2013 | Honeywell Furnace Air Pressure Switch...
Heating wont come on. honeywell system the request box in kitchen requesting for it to come on but thermostat not coming on and boiler in garage not kicking into action hve tried resetting both thermo
Check transformer near on on boiler circuit board. the transformer provides a low voltage power source to operate some thermostats and relays at the furnance control board. May need new transformer also check wiring to thermostat
Sep 25, 2017 | Honeywell Programmable Thermostat Heater
2013 Honda PCX 150 engine noise
Hi, Anonymous I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
2. Belts---CHIRP
6. Cylinders---PING
8. Fenders---SCRAPE
9. Fronk Forks---Plunk
10. Fuel pumps---WHIRR
11. Gears---WHINE
12. Head Gasket---HISS
13. Hydraulic Lifters---TAP
14. Instrument Clusters---BUZZING
15. Kick Starter---GRINDS
16. Pistons---SLAP
17. Power Valves---CLINK& RATTLE
18. Radiators---GURGLE
19. Rear Chains---RATTLE
20. Rear Shocks---SQUEAK
21. Relays---CLICK&BUZZ
22. Shaft Drives---WHIRR
23. Shifting Trans---CLUNK
24. Solid Lifters---TICK
25. Speedometers---bzzz
26. Starters---CLICK
27. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
Top 6 Strange Motorcycle Noises What They May Mean
How to diagnose problem by the noises your bike makes
Honda 2013 2014 2015 2016 2017 PCX150 PCX 150 service manual Download... $30
https://www.partsfish.com/page/oem-parts-for-honda
Honda PCX150i Owner Manual
Jul 05, 2012 | 2013 Honda PCX 150
Utica Boiler model # MGB100HD with a Honeywell Aquastat Relay model # Type L8148E will not operate the circular pump. THe damper works and I can hot wire the circulator pump but it won't turn on...
how did you hot wire it. did you jump the wires on the relay board or use another power source? Does the boiler burner start? Have 120 volts incoming to the relay board? You hear relay click when turning power on/off? If so bad relay, or loose wiring terminals on the board. This control has built in transformer that can burn out, that will stop the pump relay contacts from working.
Nov 07, 2011 | Honeywell Programmable Thermostat Heater
What should ther honeywell relay read in ohms on a r8222u 1006
did you check power to the gas valve? Pilot lit? Or electronic pilot on? Need more info on boiler.
Nov 05, 2011 | Honeywell Programmable Thermostat Heater
2004 Honda Metropolitan loud clicking noise
Hi, Karensl1970 I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
2. Belts---CHIRP
6. Cylinders---PING
8. Fenders---SCRAPE
11. Gears---WHINE
16. Pistons---SLAP
urbanscootin com Honda Metropolitan Scooter Forum View topic Scooter won...
urbanscootin com Honda Metropolitan Scooter Forum View topic Clicking...
Honda 2002 2003 2004 2005 Metropolitan CHF50 service manual Download... $25
Honda CHF50 2007 Metropolitan Owner Manual
Aug 13, 2011 | 2004 Honda Metropolitan Base
2005 Yamaha XTZ 125 X has a ticking noise
Hi, Scoobyoconne I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
2. Belts---CHIRP
4. Rear Chains---RATTLE
5. Cam Chains---CLICKIT
6. Clutches---CHATTER
7. Cylinders---PING
8. Fairing Panels---WHISTLE
10. Gears---WHINE
15. Pistons---SLAP
XT125 clicking sound
YAMAHA XT125X FULL SERVICE REPAIR MANUAL 2005 2014 Download Manuals... $15
OEM parts for Yamaha
YAMAHA XTZ 125K Owner Manual
Oct 19, 2017 | 2005 Yamaha XT 125 X
No hot water honeywell st6400c
HW valve was stuck in the open posiion and the micro-switch was not working so thats why boiler and pump were not starting. Bled system to below the level of the valve to be changed, and replaced valve with a drayton ( easy quick change of valve head if needed no screws )
Sep 07, 2008 | Honeywell Programmable Thermostat Heater
Frymaster Dean 2424G Deep Fryer Logo
179 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
