Question about Microsoft Windows XP Home Edition
When i double click on my item it does not come up
When I double click on My Item to open it up to complete it or put it in to be uploaded it won't open up but I can open items in my active log or sold items and they pop up Help please
Amar
Posted on Mar 08, 2009
I've lost restore down in Word. How can I get it back?
if you are referring to microsoft word
Microsoft Word is one of the most widely used text editors in the business world today.
Using Word, you occasionally experience glitches like missing Menu items.
You open Word and while preparing your document realize the Menu item you want to use has magically disappeared.
You can restore it easily.
There are ways to restore lost Menu items in Microsoft Word.
Check your Menu to confirm the button you are looking for is really missing.
Microsoft Word is intuitive and continually adjusts to show the options you choose most often.
Click the double arrow near the bottom of the Menu items to reveal the hidden options.
Click the Menu item you are looking for.
Use that Menu item often and Word will place it in your Menu for easy access.
Replace the missing Menu item in Microsoft Word. Click Tools - Customize.
Select the Commands tab.
Click Rearrange Commands.
Add the Menu item you lost in Microsoft Word.
Select the Menu bar at the top.
Use the drop down menu to select File. Open Controls.
Highlight the Menu item under the File menu and click the Add button.
Select File under Categories. Open Commands and select desired button.
Click Ok.
Word will reveal a preview of the File menu including your changes.
Select the desired Menu item.
Click Add.
To adjust the position of the Menu item you added.
Click Move Up or Move Down.
Continue to adjust them until you achieve your desired results.
Click Close to close the window.
Click File, Exit to close Microsoft Word.
hope this helps
Oct 14, 2012 | ASUS P5PE-VM Motherboard
Tip
How to add pictures in your eBay listings
To upload pictures with the Standard Uploader:
  1. Click the "Add pictures" button in the "Bring your item to life with pictures" section of the Sell Your Item form.
  2. If the Standard Uploader isn't the default uploader, click the "Try the Standard Uploader" link in the upper right of the window.
  3. If Adobe Flash Player isn't installed, you'll get a prompt to install it and a link to where you can. Install Flash Player if needed.
    Note: When installing Flash Player, you'll be redirected to the Adobe Flash Player website.
  4. Click the "Browse" button.
  5. Locate the pictures you want to upload.
  6. Select the images. If you'd like to upload more than one image at a time, hold down the CTRL or SHFT key while clicking on the images.
  7. Click the "Open" button in the lower right of the box to select pictures.
    You'll see picture placeholders with your picture titles and a "Pending" status on the upload page.
  8. Click the blue "Upload" button in the lower left corner of the page.
    You'll see a progress bar indicating the status of your upload.
  9. Once the upload is complete, you'll be directed back to the Sell Your Item form where you'll see your images in the "Bring your item to life with pictures" section.
To opt out of the Standard Uploader:
  • Click the "Basic Uploader" link in the upper right of the screen.
on Feb 20, 2010 | Computers & Internet
Tip
How to file for the Significantly not as described dispute - eBay buyers
Here's how to open an Item Significantlt as Described Case:
1. Go to your "My eBay" page.
2. Under "Account" (or "My Account"), select "Resolution Center."
3. Under "I bought an item," select "I received an item that does not match the seller's description."
4. Click "Continue."
5. Enter the item number or select from your recently won items using the "Find Item" button.
If you click "Find Item," you'll get a popup window. Simply select the item, then click "Continue."
6. Click "Continue."
7. In the "Describe the case" page, select the payment method you've used to pay for the item, select the payment date, then click "Continue."
8. Review the tips provided. Click "Continue," if you're sure you want to submit the cas
on Jan 21, 2010 | Computers & Internet
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
I have paid for a phone the money transfered but now the item isnt in my won list anymore why is this have i been ripped off if so what can i do to get my money back?
If you paid for your auction using paypal, then you can track the item in that account. Log into paypal, select recent transactions, find the phone and you can check the order on it. You can see when it ws paid for, when the seller said that they shipped the item, a tracking number for the delivery information and the method that it was sent. If it has been a long time since you paid for it and you still have not received it, then click on "open dispute" and report the seller to paypal. When you open a dispute, paypal contacts the seller and they either provide proof of delivery or they refund the money.
If you used a credit card to pay for the phone through the pay my auctions method on Ebay you will need to find the auction that you won in order to check delivery on it. The item should be in your closed, or completed items in my Ebay.
If you paid for the item on a credit card and you didnt go through paypal, and you cannot find the auction that you won in my ebay, then either wait until you get your credit card statement and turn it over on the back to fill out the dispute an item instructions. ALWAYS put disputes in writing when dealing with a credit card company or bank. If you dont want to wait to receive your statement to dispute the charge then call your credit card company and tell them that you want to dispute an item and have them take a claim for you. Tell them the reason is non receipt.
Jan 14, 2011 | eBay Auctions
Clicks are very fast and difficult to select something without it opens
Assuming you have a PC, go to control panel, click on mouse and there you can set the click speed for double clicks. Another way to prevent this is to go to folder options and tick the button for 'single click to open item - point to select' That way you highlight (select) an item by just moving your mouse onto it and open it by only clicking once. Hope that helps
Jul 24, 2010 | IBM Lenovo Mouse 76H6618
Auctions: I purchased an item and is was not exactly as desc...
With regard to this, you will need to file the item not described dispute so that you can get your money back.
Here's how to open an Item Significantly not as Described Case:
8. Review the tips provided. Click "Continue," if you're sure you want to submit the case.
May 16, 2010 | eBay Auctions
How can i set my laptop cursor to open a file by double clicking?my laptop cursor is moving but it cant open a file, or its not working when i click the file to open.
Try going to start, control panel, Hardware, then Mouse and check your settings. Make sure the double clicking speed isn't set extremely high.
Mar 01, 2010 | Toshiba Satellite A135-S2276 Notebook
How to put a photo on Ebay
Here's how you can add pictures in your eBay listings.
Feb 14, 2010 | Computers & Internet
In e-mail cannot get item in draft back to 'send'
double click the item in drafts, it will open allowing you to continue editing. Once opened the sens button will appear again.
Hope this helps FixYa,
Chris
Aug 16, 2009 | Acer Aspire One PC Notebook
Microsoft Windows XP Home Edition Logo
24 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
