Question about Linksys Wireless-G Broadband Router
Cannot connect to 192.168.1.1
When I enter this in browser nothing happens. It goes no where. It used to go to another screen. I have a new router I just installed which is a Range Plus wirelass router.
  • 1 more comment
  • mhabib May 11, 2010
    This is what am getting:
    401 Unauthorized
    Authorization required.
    IP address is the same, didnt change?
  • mithrandi13 May 11, 2010
    at any point were you trying to load a custom firmware on it? Make sure it's still using the same gateway address by going to control panel->network connections->double click on the wireless connection->support tab and seeing what the default gateway is. it should still be 192.168.1.1 but if not go to the address it mentions there. Also you can try reseting the router by holding down the small pin button on the back of the router to see if that fixes things, but it'll reset all your setting when you do that.
  • 68 Answers
It could be that your IP address of the router changed.
If you are using windows start cmd window and type: ipconfig.
When the result is displayed look for line 'Default gateway'.
Type those numbers in your browser prefixed with http://
Posted on Mar 08, 2009
I want to connect my tv to wifi but i couldn't find the setup menu
first your tv needs to be a "smart" type tv set this has both a wired network connection and a wifi connection if it does not have this you will need a converter , you will need your routers password , as you will need to authorize the tv in the routers set up (yes even if you have a dhcp router ) , turn tv on if your using a universal remote most times they cant access the tv set-up menu (on purpose ???) anyways find the tiny buttons along edge to set id bet its near the power button , till you find "menu" press this it will bring up a new screen on tv , use your up/down arrows on remote to go to network , press enter on remote this will bring up a new screen , select "enable" on wireless network an press enter key , this will bring up a new screen it should after a few minutes show a list of routers It can "see" select your routers name using up/down arrows on remote and press enter , a password prompt should show up , enter the network password (from router) and press enter when done , takes a few moments but it should finally say connected (if you did it right ) then exit out of this and bring up "browser" from your menu , this will look like a normal pc browser an you can enter your destination from there , this is a general set up method your tv might be slightly different but this shows suspected path to follow
Jan 22, 2016 | Televison & Video
I just received my tablet and I cannot open browser to the website. I am hooked up to a router and it tells me it is excellent.
The question is does the "router" have access to the internet? Do you have some other device/PC using it to access the net?
You question is also confusing. Is the browser software not loading correctly or when enter a website like www.google.com nothing happens?
Dec 09, 2014 | Tagital Tm 9" Android 4.0 Tablet PC...
Wi-Fi connected, browser not loading
first u have to check if u can ping the ip address of the router , if u can try to see if the dns settings are correct
Mar 06, 2014 | D-Link Computers & Internet
I am trying to install a wireless printer and it says I need to put in the ssid and passphrase for my router. How do I find out what that is when my manual shows nothing??
For your to access the router just open a browser then enter 192.168.10.1 on the address bar the look for the wireless settings page . you'll see there the SSID or Network name and the passphrase or the Network key that you need to connect the printer wirelessly.
And also if 192.168.10.1 wont work. try to get the default gateway of your ccomputer thats connect to your router. Just click on Start then go to RUN, enter CMD on the small dialog box on the lower left of your screen, Then on the black window type IPCONFIG. The defaulti gateway will be the address of your router input that on the address bar of your browser to access the router pa ge
Thanks for using Fixya.
Jan 27, 2011 | Intellinet Active Networking Intellinet...
Hello there, need to know how to config a phone line modem Zhone 6381 I guess its called the Zhone 6381-Ax Router. I happen to prees the reset button and losst the programed IP. how can I go about...
To configure your router, make sure you are connected to it first, open your web browser. Ignore any error about lacking a connection. Type the default IP address (192.168.1.1) into the Location field of your browser and press the Enter key. The following screen appears.
The default user name is Admin and the password is Admin. Both are case-sensitive.
Note: You should have your PCs configured for DHCP mode (if your router will be), and have proxies disabled on your browser. If you see a login redirection screen when you access the web interface, verify that JavaScript support is enabled in your browser. Also, if you do not get the screen shown above, you may need to delete your temporary Internet files.
The first screen that appears after the log in screen is the Home page.
From this screen you can configure the LAN and WAN connections, configure the router's security, routing, and filtering, access debugging tools, obtain the status of the router, and view the online help.
From here, go to the Setup Tab and click the New Connection on the left.
Input your numbers and don't forget to save.
Hope this helps!
Dec 21, 2010 | Zhone (6218-I2-200) Router
Itouch won't connect to my wireless internet
I had exactly the same problem with a brand new 3rd gen iTouch. It showed it was connected to the network but wouldn't access anything (invalid argument etc). I tried everything but no joy. Eventually I fixed it by changing the router's encryption from WEP to WPA2-PSK. Fixed it like magic. Where there had been no router or DNA data before, they were suddenly filled in. The key was different but was still on the bottom of the router. I had to re-enter the key on my wireless laptop2_bing.gif but that was a small price.
You can get into the router set-up page through your web browser. I found a guide on You Tube.
Sep 21, 2009 | Apple iPhone Smartphone
Trouble getting my router to go to wireless
A few things to look at:
1) On the front of the router, is the wireless LED lit up?
2) If it is not then it is either disabled or dead. Connect the router to your pc by cable and in a browser window enter 192.168.1.1.
3) At the login screen enter admin for the user and password for the password.
4) Once you are logged in, use the wizard to setup your wireless connection.
Good luck and thanks for using FixYa
Mar 26, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Random DNS Error
You may need to manually configure your PS3 connection on the console. Let's see.. I can suggest to first go to your Settings Menu -> Network Settings -> Choose:"Settings and Connection Status List" this will display a pretty detailed information about your connection to your local gateway (router).. Check specifically for Primary and Secondary DNS. In my experience, using the PS3's auto setup for the connection seems to enter the default gateway's ip (labeled "Default Router" on PS3 Status Screen) in place of the real DNS entries..
Question
: Sooo how do you check your primary/secondary DNS for your network? Answer: On your PC, open a web browser and enter your default gateway ip into the browser.. log into your router (assistance can be found in your router manual or by calling your router manufacture). You should see a status page of sorts that displays your ISP's primary/secondary DNS entries.. Simply transfer those two IPs to your PS3 manually to correct the DNS issue.
Hopefully that should resolve your issue!
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing 192.168.0.1 in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see http://www.fixya.com/ThreadView.aspx?thid=102081&prdid=252188 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Feb 19, 2006 | NetGear FR114P Router
Linksys Wireless-G Broadband Router Logo
402 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
