Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick rebooting my sidekick 3 will is stuck on the reboot problem and i just wanted 2 know if i by a new battery will it fix the problem
  • 33 Answers
Huh? i am not sure i understand what your saying.....?
can you repeat what your saying again, please if you can. thanks.
Posted on Mar 10, 2009
I have a sidekick 3 and i want to restart it
HOW TO DO A MASTER RESET ON A SIDEKICK 3 1. Remove the battery and the SIM card from the device.
2. Flip the sidekick open; press and hold the letter 'r' on the keypad.
3. While holding the letter 'r', place the battery back in the device. DO NOT INSERT THE SIM CARD YET.
4. The sidekick will restart itself twice. Please make sure not to let the letter 'r' go until it has fully rebooted.
5. Once it has fully rebooted, remove the battery, re-insert the SIM card and battery and power up the device.
6.Once the device has fully rebooted, all prior information should beerased from the device and it should be restored back to the defaultfactoy settings.
Nov 30, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Tip
Device randomly reboots - T-Mobile Sidekick® II (all styles) / Sidekick® 3 (all...
Device randomly reboots - T-Mobile Sidekick® II (all styles) / Sidekick® 3 (all styles) / Sidekick iD
  1. Check the device's battery level for at least two bars of strength.
  2. If the battery level is low, charge the battery.
  3. If the issue is not resolved, remove the back cover.
  4. Remove the battery.
  5. Wait 10 seconds.
  6. Press and hold the W key.
  7. While pressing down the W key, re-insert the battery.
    • The device restarts and after approximately 15 seconds, the 'Recovery' screen appears.
  8. Select the desired language.
  9. Select Reboot to restart the device.
on Dec 09, 2008 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile sidekick II keeps resetting
I had this problem with a new phone, and T-mobile gave me the following instructions.
Try this first:
1) Turn on phone with SIM chip in it.
2)hold down the "@" + "1" + "0" down simultaneously until phone turns off, then back on again. This should fix the problem. otherwise try this,
1) remove battery and SIM.
2) press and hold down the "w" key, and while holding it down insert the battery only.
3)A little face will appear on the screen, then a reboot button. Press the reboot button. Once the phone reboots, insert the SIM. One of those two should fix the problem.
Oct 04, 2009 | T-Mobile Sidekick II
SIDEKICK LX
Here is your solution:
Now follow these steps to a "T" don't do any shortcuts etc, this is "across the board" for all sidekicks it worked on my Sidekick Slide and on my Sidekick 2008.
1. Remove battery and the SIM card from the devise.
2. Flip the sidekick open; press and hold the letter "r" on the keypad
3. While holding the letter "r", place the battery back in the device. DO NOT INSERT SIM CARD YET.
4. The Sidekick will restart itself twice. Please make sure not to let the letter "r" go until it has fully rebooted.
5. Once it has fully rebooted, remove the battery, reinstall the SIM card and battery.
6. Power up device.
7. Once the device has fully rebooted, all prior information should be erased from the device and it should be restored back to the default factory setting.
Oct 03, 2008 | T-Mobile Sidekick
Sidekick 2008
ok u dont have to get a code on the 3 digit mian screen press menue and circle the press menue shits q then its ganna say delte evry thing press yes and ur promblems solve i had the same promblem
Sep 29, 2008 | T-Mobile Sidekick® 3 Cellular Phone
The sidekick Lx
You can try this. It works on Sidekick 3's
1. at the same time hold the menu button (top left) and the jump button (bottom left)
2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
4. The phone will reset and clear/unlock the security code
If that doesn't work you can trya Master Reset
6. Once the device has fully rebooted, all prior information should be erased from the device and it should be restored back to the default factoy settings.
Thanks to Sidekickskins.net
Feb 03, 2008 | T-Mobile Sidekick
Sidekick 3 crsashes
The same thing happened to mine, so far what i do is do the hard reboot:
take the battery out, hold down w, while still holding the w put the battery back in. then scroll to reboot.
may take a few tries....
also this is an annoying and very temporary fix...get a new phone.
Jan 22, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
Emulating a Hard Reset
The Sidekick 3 now will commit memory-resident DataStores to flash memory when the device is powered down or rebooted normally. This greatly reduces the incidence of "hard reset" resyncing of the device which enhances user experience, however it makes it more difficult for developers to test this functionality on the device. You can simulate a hard reset on the device two ways: 1) Yank the battery out of the device without shutting it down. This will force a hard reset of the device, but it's not recommended as this can also potentially corrupt files on the miniSD card if they're being written when this happens. 2) (recommended) Follow the steps below to clear the datastores off and simulate a hard reset:
- Reboot the device by pressing @+1+0
- IMMEDIATELY press and hold the 'R' key on the keyboard. Continue to hold the 'R' key down
- The device will reboot, and when the initial boot screen (the 4 face buttons animation shows) displays, the screen will clear and the device will reboot again.
- Let go of the 'R' key at this point, and the device will reboot with no datastores, and force a resync.
Jan 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Subject i have a t-mobile sidekick id
You can try a master reset.
Dec 12, 2007 | T-Mobile Sidekick® 3 Cellular Phone
PLEASEEEEE HELPP!!
you could go to the t-mobile store and ask them im sure they have it
Nov 29, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
55 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
