Question about Home
PLUMBSHOP HUSHFLO #516 Toilet anti-siphon/valve replacement Kit- The tank continues to fill very, very slowly after shutting off. Can the valve be cleaned? I have sediment problems with grit in the plumbing lines in the other bathrooms! Thank you.
  • Anonymous May 03, 2009
    I have purchased two Hushflo valves today 5/2/09 and both of them had the same problem.
  • 659 Answers
Usually, there is a diaphram located at the needle valve that can be removed and cleaned and or replaced. If you know you have grit in the water, then you are right, that will cause problems with the fill valve not fully closing.
Posted on Mar 20, 2009
After the tank fills on the toilet, every minute a bubble will float to surface coming from the re-fill line. I just put a new flapper due to old one was sticking open. No leaks, but wondering if the seal to the siphon is an issue.
Posted on Jun 09, 2009
How to fix a refill valve
  • Brass-style toilet refill valves can often be repaired. To take a valve apart, remove the lever's screws. This allows you to lift out the float arm and valve plunger. Check the flat rubber washer on the end of the plunger. If it's worn, you can pull it out with pliers and either turn it around or replace it. This procedure usually corrects an overfilling problem. Next, reassemble the valve. If the tank continues to overfill, check to make sure the operating lever at the end of the float arm is functioning properly.
  • New refill valve. To replace the entire refill valve assembly, first turn off the water supply. The tank should then be flushed and sponged out, as detailed previously. Remove the inlet nut and riser tube from the bottom of the refill valve beneath the tank. Hold the refill valve inside the tank with a padded locking plier/wrench to keep it from turning, and remove the nut beneath the tank. With the nut off, the refill valve assembly can be lifted out and a new one inserted in its place. Follow the exact instructions included with the unit you purchase.
  • Finally, reconnect the riser tube and turn the water on. The tank should fill, allowing you to adjust the water level according to the instructions that were included with the valve.
  • Anti-siphon valves. The best refill valves offer anti-siphon protection. In fact, this may be a requirement. This protection prevents back siphonage of toilet tank water into your home's potable water supply system if a vacuum occurs in the toilet's water supply system. Whether or not this is a code requirement, the anti-siphon valve is a good idea to protect your family and public health.
on Jan 16, 2010 | Plumbing
Our local housing inspector says a toilet fill valve must be anti-siphon. I have Kohler k-9262 fill valves in my bathrooms. Are these anti-siphon models?
the fill valve is under constant mains pressure so it will not siphon out. However if there is a problem you can buy a non-return valve from your local hardware/plumber shop and fit it in the line between the cistern tap and the cistern
Jan 28, 2015 | Kohler Home
Toilet repair, anti-siphon fill valve
buy a tank valve replacement kit at ur local hardware store and replace it instuctions in box.
Mar 08, 2012 | Coffee Makers & Espresso Machines
Korky anti-siphon. Tank water slowly drops, accompanied by a hissing sound. Then, after dropping about 1/2 inch, it refills. Wha?
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl slowly...causing the fill valve to run every few minutes or so. hope this helps but if you need anything else just text me here:)
Jul 29, 2011 | Lavelle Industries Korky& Universal Toilet...
Hushflo anti-siphon toilet valve will not stop filling.
make sure the float is not stuck or if it doestn't have a float move the head on the unit around sometimes they stick
Aug 11, 2010 | Home
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Gmax flushing system won't stop
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
Hushflo valve
fluid masters are cheap and available every where i would just replace it
Apr 19, 2009 | Home
Home Logo
3,314 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
