Question about Panasonic KX-FPG381 Plain Paper Thermal transfer Fax
Change setting from receive to transmit
How do i change to transmit from reciceive fax
What do you mean? You just place your document, dial the fax number, and press 'start'
Posted on Mar 09, 2009
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
How do I change the setting in order to use fax on voip line?
Hi
The data transmitted during a voice call and a fax transmission are converted to digital pulses in the same way, so sending is not the problem. The problem is at the receiving end. A receiving fax device has to be set to pick up the call before the voice call device, as it is the prompt of the fax transmission signal that makes the receiving fax switch from send or idle to receive mode.
So, if you are faxing over the internet the intended recipient's setup is a complicating factor.
Since faxing to landline fax machines via VOIP would incur a charge, you might consider a cheaper software solution such as eFax (www.efax.com), which enables the receiver to receive the fax as a PDF document attached to an e-mail.
I hope this helps
Aug 26, 2011 | Ricoh AC104 All-In-One Laser Printer
We have two fax machines hook up to one dedicated fax line. When we send a fax from wither machine it is not faxing to the phone we fax it only sends the fax for the second fax machine that is in our...
Yes, you must set up your fax machines like this: The receiving fax must be set to auto receive and the telephone line must be inserted in the "line" input. A line must then be connected from the "Tel" to the "Line" of the Transmitting machine, which must be set to "manual receive." This is not really a satisfactory way of doing things as you can't send and receive 2 machines on the same line together. A much better way is to have 2 lines. with a machine attached to each. Get the tel company to put "No answer transfer" on the line as an accesory. Give them the number of the fax machine that transmits. Make it "manual receive" Now you have a versatile system that you can also use the office telephone with.
Oct 05, 2010 | Brother Office Equipment & Supplies
Not always receiving fax digital analog problem ?
prety sure there is no such thing.Most likely its your line.
Mar 30, 2010 | Brother IntelliFax-2820 Laser Fax
Okifax 5680 - transmit resolution issue
You can change the Transmit Resolution but not the resolution or the quality of the faxes received.
If your machine makes goog copies and prints, the problem is on the sender's side.
This is an excerpt from the troubleshooting section of your machine manual:
The image received on your fax machine was very poor. Contact the person sending you the fax and ask them to change their Transmit Resolution and Type of Original settings. Ask the person to make a copy of the document on their fax machine to ensure that it is working properly. Then ask them to send the fax again. If you still have a problem, try making a copy of a document on your machine to make sure it is working properly
Aug 14, 2009 | OKIFAX 5680 Led Printer
Get communication problems when sending some faxes - when sending faxes to some places it won't transmit but will transmit to other places
The problem can be either a error with your phone service or an incompatablity with your machine and the receivers.
Sometimes the problem is as simple as the receiver's machine being set to receive on more rings than your's before it goes into redial.
Apr 15, 2009 | Office Equipment & Supplies
How do you change the transmitting speed from 14,400 to 9600 ?
Fax machines are ANALOG devices, your fax will not work reliably on a DIGITAL phone line. There are no analog packets.
Jan 05, 2009 | Brother MFC 1970MC All-In-One InkJet...
Probllem receiving a Fax
No, the solution you provided I had already done. Problem is not solved as it was guarranteed, but I was charge for it and you still want me to purchaed the premium solution.? Get real!. my charge should be refunded..Very dissatisfied.
Mar 30, 2008 | Lexmark X4270 All-In-One InkJet Printer
How to change the receiving tray for faxes?
Look around for a small lever or lock that you adjust for one way or the other. open the top front and look to the left. it might be there.
Feb 12, 2008 | Canon FAX-L200 Plain Paper Laser
Panasonic KX-FPG381 Plain Paper Thermal transfer Fax Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
