Question about Epson Stylus CX3200 All-In-One InkJet Printer
Epson stylus CX3600 E light flashing, all green lights flashing
2 red lights on too. What can I do to solve this? Operation guide suggests that it needs a service. I'd rather fix it myself.
  • Anonymous May 06, 2009
    same as melindapaines - E light flashing, all green light flashing, two red lights on.
  • joanjo May 12, 2009
    Printer indicated that the yellow cartridge needed changing, I changed it then the two red lights came on and all the other red flashing lights. what now?
Epson CX3600- 8 FLASHING LED`s and Error code
Posted on Apr 25, 2009
Posted on Dec 04, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I need reset software for epson cx3600 as i have two red flashing lights and flashing E
The SSC utility will allow you to reset the waste counter on this printer... You may find that this is a general error though in which case resetting won't make any difference.
Link for SSC:
http://www.ssclg.com/epsone.shtml
Jul 27, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Have flashing lights from Green to Red with no
Sounds like a maintenace pad problem (every Epson printer has a different set of flashing lights to indicate this "Maintenacne request"- read this link: http://www.epson.com/cgi bin/Store/support/InkPadsForm.jsp
Jun 01, 2010 | Epson Stylus C46 InkJet Printer
Epson Stylus CX3600 error
remove the cartridges then, the press and hold all the available buttons on your printer where it could cause a machine resetting...
you could also remove the cartridges then wipe the circuitry of the cartridge... (the gold-like connector)
then turn off your printer without putting back the cartridges... (leave it turned off for 5 minuets)
turn your printer on then it should be ok
(post back if it doesn't work)
Jul 07, 2009 | Office Equipment & Supplies
Restart your computer and power-cycle your printer off and back on.
Make sure the paper tray is not overloaded.
Make sure the paper in the tray firmly pushed into the paper tray towards the printer.
Jun 28, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus c45 prints abruptively
green light flashing and red light is blinking cannot print
Feb 18, 2009 | Epson Stylus C46 InkJet Printer
MY EPSON STYLUS PHOTO R200 HAS THE RED A GREEN LIGHT FLASHING
WWW.EPSON.COM/SUPPORT AND DOWNLOADS, WHEN YOU FLIP OPEN THE COVER SEE IF THE UNDERSIDE HAS A INSTRUCTION APPLET ON CLEANING AND REPLACING INK CARTRIDGES, THOSE LIGHTS MEAN 2- THINGS RED-LIGHT, INK IS TOO LOW,NEEDS REPLACEMENT, RED WITH GREEN AFTER REPLACEMENT CLEAN HEADS, I HAVE SAME PRINTER , NOTHING MAJOR, USER GUIDE IS ON SITE ALSO IN PDF, FORMAT.... JON T
Dec 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Urgent: red light error on Epson Stylus CX3650
It appears that this is an overseas model (at least for those here in the US that is) as far as I can tell. This will use the same drivers as the CX3600 model though. Depending on how long you have had this and how often you use it, you may have a waste ink reset situation. While I have not had any personal experience with this model, there are several references on the internet on how to do a reset. There is even an "SSC Service Utility" you can search for that lists this printer as being supported. It cannot reset the ink counters but it may reset the waste.
Good luck, I hope this is of some help.
Oct 18, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epsom stylus c60
For the record, problem solved!
Mar 05, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
1,681 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
