Question about Toshiba Satellite M100 Notebook
Mucking around and disengaged biometric fingerprint power on mode....now cannot get access as machine wants bios code..????? (know it is 3 didgits but what ?????
How do i use bio metric censer in hp Compaq nc6320
To use the Biometric fingerprint sensor, just swipe your finger across the reader and it should start the enrol program.
See the video on this page Using Fingerprint Reader with DigitalPersona or Verisoft
Oct 10, 2014 | Computers & Internet
I forgot password of ls-838 lonestar biometric
The password is present to prevent the usage of it by a thief after it has been stolen.
May 25, 2014 | BestPriceCables Lonestar Biometric Time...
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
I have a Adel Trinity 788 biometric fingerprint handle that I need to install. I lost the screws and I am trying to find the 3 long bolts that connect the 2 halves together. Does anyone know where to...
Trinity Keyless Biometric lock:
I can't answer your question directly, but I can steer you to their website, which includes a support phone number that you can call, as well as links to Customer support and Frequently Asked Questions:
http://www.axxisbiometrics.com/products/locks/latch-style/trinity788/
I'm sure they can answer your questions. Good luck!
Apr 10, 2011 | Trinity Keyless Biometric Fingerprint Door...
U.are.U 4500 fingerprint reader cannot communicate with the jamb capture software.
1. This kind of problem happens when you re-formatted your computer
2. You just install your scanner this year
3. You did not have biometric license installed on your computer, this license makes your scanner authenticated over the internet when you are visiting jamb website, if you are in Nigeria. It also comes with Jamb Biometrics Capture Software, .Net Framework, Java Framework and other software that will make your experience very simple after installing.
4. If, you have the license, then you did not supply the 16 digit security code for the scanner.
The way you out, you need BIOMETRIC LICENSE, if you are operating JAMB BUSINESS.
Hope this help you, if you need more clarification you can email me on biometricmasters2000-jamb at yahoo.com or phone me on 08132829820
Feb 26, 2011 | DigitalPersona UareU 4500 Fingerprint...
I have a Trinity Keyless Biometric Ringerprint Door Lock Adel 788. The scanner reads my fingerprint but the internal lock/unlock won't operate. I already tried resetting the lock to factory out of the...
This is the website for Axxis Biometrics, the manufacturer:
There is a phone number and email address which you can use to contact them for technical support.
Feb 14, 2011 | Trinity Keyless Biometric Fingerprint Door...
We have a biometrics gadget in the office to monitor time in and out. My finger prints are so shallow that the machine always fails to recognize my finger print. What do i need to do.
to sign my daily (though a fingerprint machine )attendance I face continuos annoying problem which the fingerprint machine can't identify me in spite of I changed the fingerprint from finger to another but everyday i face this disgusting problem .\r\nwhat can i do?
Aug 31, 2010 | Precise Biometrics 100 AX
Error: Biometric Fingerprint reader not connected.
www.dellsupport.com enter your service tag number. nice folks, very helpful
Sep 03, 2009 | Dell XPS M1530 Notebook
Couldnt Find fingerprint equipment
Let me elaborate on what the other two were telling you. First, your fingerprint reader is a scanner, if it is showing up as a scanner then you have the device installed. Second it may not have the right driver installed so that the biometric software doesn't realize it's the right device.
First you need to install the driver from the backup you made for the fingerprint scanner. If it doen't work or is not on the backup then you neew to go to www.acer.com pick your region, then get into the driver downloads for your model. You will need the full model # ex AS5730-54857 off the bottom of the laptop to get into the downloads. Once you're in download the newest update for the finger print scanner.
Once you have that installed it should show up properly in the device manager and the biometric software should recognize it. It is always important to install the drivers before the software for these devices as otherwise they will not work. The software installer needs to see the proper device at the time it installs, so if the biometric software is currently installed, remove it then proceed with installing/updating the driver.
Chris
May 26, 2009 | Acer Aspire 6930-6455 Notebook PC
SentrySafe DA3930 Biometric Fingerprint Safe Item Number 681814 will not recognize my finger print!!!! I have been trying to get into it on and off for 3 months. Is there a reset code???
contact sentry
biometric scanners DO NOT WORK
prove your ownership
and they may assist you
and
Sep 14, 2008 | Sentry Fireproof Safe
Computers & Internet Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
