Question about Dell Inspiron 1200 Notebook
My Dell Laptop has slowed down considerably. Can
My Dell Laptop has slowed down considerably. Can you help?
  • jdicanio Apr 06, 2009
    when i power on my computer, it takes 10 minutes to start up. Only 3yrs old. It is Dell Inspiron E1505
  • Nicholas Lussier May 11, 2010
    Hello, what windows is on it? Do you have any spyware protection?, How many icons load up in the bottom right corner by the clock?
    Master:
  • 404 Answers
For Total speed boost
laptops overtime become slow so they need a little tlc time to time
I created this method so you can do it yourself.
first’ up delete the filthy files, the internet junk that you don't need
by doing a disk clean'up, simply right click on the hard drive C and
go to proprieties then chose disk clean'up.
after that, delete some hidden programs and stuff you don't use anymore
by going to start, control panel, add and remove programs then delete what you
don't need. especially java updates delete all of them leave just one.
now run your antivirus and scan for any viruses and spams.
after that move'up pictures and files you don't need anymore into dvds or cds.
now run a defragmenter by clicking on start, run, write defrag and run it
then a table will come'up select the C drive and defrag, this will take
around 1h.
now restart your computer and it should be faster.
>> www.laptopquestions.co.uk
Posted on Mar 07, 2009
Slow comp!!
Adding more RAM can speed up a Laptop.
Feb 24, 2012 | Dell Computers & Internet
Very slow computer
You are frustrated with the slow performance of your Dell laptop? You can quickly fix this slow PC problem and prevent it from happening again, all with a few clicks. Simply apply some easy tips as discussed below to make your Dell laptop/computer make faster - http://technical-support-squad.blogspot.in/2012/08/make-dell-laptop-run-faster-how-to.html
Feb 12, 2012 | Dell Inspiron B130 Notebook
My new conputer donwloads incrediby slow on DSL. How can I speed it up? I use an older laptop on the same DSL via wireless network which is considerably faster. The newer comnputer has a faster processor...
Complaint to your DSL provider for slow speed. As possible, integrate your RAM and processor. Download with DAP (Download accelerator plus) and install Google Chrome for fast surfing. Install a licensed antivirus or registry booster.
Jul 24, 2010 | Dell Computers & Internet
Dell latitude c840 slows same time fans come on, approx. 4-5 minutes after start-up. Ran laptop in cool, not cold environment; no noticable improvement.
have the unit cleaned out good...if problem still exist your laptop may be on its way out
the slow down is due to a drop in power available to the processor, and this can damage it beyond repair.
Mar 31, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell precision m90 overheats randomly
Either your motherboard has gone bad, or you fan AND cooling grid needs replacement. The grid is simply a series of metal bars, so to speak, which absorb heat to be passed out of your system with the cooling fan. The cooling fan has 2 speeds. If the system is not kicking in the higher speed on the fan, it's more than likely a bad motherboard. Also, make sure you keep your laptop plugged into the wall as much as possible. Going on battery alone does slow down the processor considerably to conserve the battery.
Best wishes.
Feb 23, 2010 | Dell Precision 360 Workstation/Personal...
Laptop reads cds and dvds, but drags when playing.. help. It is a dell latitude,
Make sure you connect the power adapter when playing dvds. Running on battery slows down the efficiency of ODD.
Hope this helps.
Dec 20, 2009 | Dell Latitude D600 Notebook
My dell 610 laptop has started running slow
if you are experiencing these and unsure on what to do, better take your laptop a laptop tech, if you feel that you needed a hard drive change, then take it to a tech, have them replace your old hard drive
Nov 26, 2009 | Dell Latitude D600 Notebook
Slow computer
I'd speak to them again, sounds like you have a faulty stick of RAM, if it freezes then it usually means one of the hex sections of the stick isn't working correctly.
May 25, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Studio laptop won't power on
are any of the led's showing that the charger is plugged in? Try few of these steps.
1: wiggle the cord slowly in different directions being patient for results-this tests for shorts in the cord
2: check different outlet
3: consider possibility you need new power adapter!
Future Considerations:
Laptop Fan Cooler! Worthy Investment and Timer for Plug in wall!
Hope it helps
Feb 16, 2009 | Dell Studio 17 Laptop
Slow speed, fan coming on loudly in Dell D800
Yeah the slowdown is the laptop throttling back due to overheating.
When you do processor-intensive work like - streaming videos - the laptop overheats. The fans come on loudly.
When the computer heats up despite the fans, the processor throttles back to relieve the heat.
When you reboot your machine, it stops performing intensive work, giving it a chance to cool down. It's not restarting that fixed the problem it's the fact that the laptop cooled down.
So here's what you do. Get an air duster and blow all the dust and gunk out from your fans. They are most likely clogged with dust and that's what's causing your cooling problems. If there are large dustballs in there, use a tweezers and pull them out. Get as much out as possible.
Dec 06, 2008 | Dell Latitude D800 Notebook
Dell Inspiron 1200 Notebook Logo
181 people viewed this question
Alun Cox
