Question about Microsoft Zune JS8-00001 Digital Media Player
Zune my zune is not working i got the software from the zune website but when i plug my zune in it says cannot install this software
  • Anonymous Mar 08, 2009
    asdgfsdfasdfasdf
  • Anonymous Mar 28, 2009
    The zune just does not work at all after a few months bought
    Scholar:
  • 145 Answers
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
Posted on Jun 02, 2009
    Sniper:
  • 84 Answers
Ether you have a anti virus system blocking it ( or fire wall) or you have to slow of a computer type
Posted on May 05, 2009
  • chris simard
    chris simard May 05, 2009
    did you try temporally disabling your fire wall also you may have to re
    download the soft ware if all else fails call micro soft or download a
    zune soft where patch
4 Suggested Answers
  • 5 Answers
SOURCE: Microsoft Zune instalation problems
you need to erase the program and then download it again
Posted on Nov 06, 2008
  • 10 Answers
SOURCE: zune reset
Hi I can help you this is how. BUY A 4G ZUNE!!!!! cause your 30g zune is broken or something, or reset everything and instal it again
Posted on Jan 31, 2009
  • 4 Answers
SOURCE: I can't install Zune Software
Are you running Windows? It will not work on a Linux System. (Not sure if it runs on a Mac)
Posted on Jul 29, 2009
NEW ZUNE WILL NOT TURN ON/RESPOND TO ANYTHING
hey bro just solved the same issue =] plug your zune player into your laptop desktop ect. and activate the lock switch the charging symbol should pop on and let it charge and your set.
Jan 07, 2010 | Microsoft Zune JS8-00001 Digital Media...
Zune won't sync and now some songs will not play all they way through
Go for software update from the zune website it will help you.
Also ensure that the settings are not changed .
Sep 25, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I double click on my zune software but it wont start
Uninstall your software. Delete those files. Plug your Zune in and let your computer locate the Zune and find/install the drivers and software for it! It should do it by itself.
Aug 13, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune software won't recognize Zune when plugged in
Go to Device Manager by right-clicking on My Computer > Properties. Depending on what version of Windows you are using you will see Device Manager somewhere (might have to switch tabs).
With your Zune plugged in, you should see it under Portable Devices or Disk Drives or something similar (look under anything that could describe the Zune).
Next there are a few things you can try:
1) If the Zune is not installed (has a yellow ! next to it), right click and update driver, then tell it you want to specify where to look, and look in Program Files\Zune\Drivers\Zune\ . The file Zune.inf should be in there, that's the Zune driver.
2) If the Zune is installed, right click and select uninstall, then reinstall the driver I specified in step 1.
That should work, if it doesn't right click on the Zune in Device Manager, go to Properties and tell us if there are any error codes or if it says the device is working properly.
Jul 16, 2009 | Sony PlayStation Portable (PSP) Console
My zune will not sync
had bought a zune from a pawn shop and the zune charges but will not sync with pc. do you know what my be wrong. i loaded the software and replugged my zune but still not able for zune to sync with pc
Jul 01, 2009 | Microsoft Zune JS8-00001 Digital Media...
Nothing wont come up on my computer
Did you download the Zune software?
The Zune website has the Zune software which must be downloaded for your computer to communicate with your Zune.
And when you connect your Zune to your computer it should begin charging (as I'm assuming this is a new device).
If you have already installed the software I would assume the low battery was slowing the communication between your Zune and your computer.
If you Zune is fully charged and the software is fully installed try plugging the USB cable into a different port. Sometimes the Zune and the connector USB isn't automatically sensed on certain ports and certain moments.
Jun 26, 2009 | Microsoft Zune JS8-00001 Digital Media...
Usb device not recognized when i plug in my zune
do you have the software installed? or a older version installed? if so that could be your problem with the drivers. try downloading the zune 3.0 software directly from the zune website instead of updating ,  here is the link to the download page
http://www.zune.net/en-us/software/download/default.htm
Make sure you uninstall any previous zune software first!
Hope this Helps
A+Support
Apr 10, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune reset
Jan 13, 2009 | Microsoft Zune JS8-00001 Digital Media...
I need to download the "ZuneDriver.dll" so I can make the software for the Zune player open. I have downloaded the software ".exe" file from the Zune site, but it fails to install because "Can't find the...
You shouldn't have to install the driver yourself! Uninstall and Delete all files connected to your Zune (except your music files!). Now, plug your Zune in, and the computer should locate/install all the necessary drivers and software needed to operate your Zune. Then, you can format/personalize the Zune software the way you want. The computer downloads the drivers for you! Try that! It should work wonderfully!
Dec 12, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
162 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
