Question about GPX CDP3104CK Personal CD Player
Want Belt Clip
Is a belt clip available for GPX CD Player model # CDP3104CK . If so how much are they and how do I get one. Thank you
  • 27 Answers
GO TO THEIR WEBSITE.
Posted on Mar 07, 2009
LID WON'T CLOSE ON CD PLAYER
The CD loading mechanism have the fault. Check its loading belt. If loading belt has broken, the try wont close of open. If loading belt is OK. replace the loading motor.
Aug 12, 2012 | GPX Audio Players & Recorders
CDC-735
Part Number VQ776900. I got it online for 99 cents but other places can be up to 7-8.00 dollars. I removed 5 screws on the sides and rear of the case. Took case off. Press the open button and help the drawer open with your hand while the motor tries to. Then remove old belt with pliers or paper clip, etc.
I did not take anything apart on the inside to replace the belt. Push the belt into the player over the larger wheel and then I pulled the belt with a paper clip over the smaller drive wheel.
Mar 17, 2012 | Yamaha CDC-755 5-Disc CD Changer
The sony model #CDP-c910 skips discs continually and does not stop to play a disc. Am interested in repairing this set or purchasing a new identical set if it is still available. The size is...
Try changing the (only) belt the player has with a brand new one. Go to www.partstore.com. I believe it costs more than $10. Clean the pulleys with isoprophyll alcohol using a cotton swab after removing the old belt.
After you remove the top cover, take a careful look how the belt is placed. Don't unscrew anything. The belt can be removed and replaced without removing any screw. A paper clip will help if you don't have the right belt removal & replacement tool. A commercial CD lens cleaner (I use Scotch brand) will greatly help. Just insert it in your magazine and run for a few seconds to a minute. This is not a sure fire solution but most of the problems in this model is attributed to an loose/overstretched old belt and a dirty laser lens. I hope this helps & good luck!
Jun 10, 2011 | Sony CDP-C910 10-Disc CD Changer
No belt clip
If you can't find the exact pouch for the mp3 player you can always do what I did and thats to purchase a cell phone carrier that your mp3 will it in =) and they are usually better than the original pouch due to thickness ;-) Hope this helps
Good Luck =)
May 29, 2009 | Audio Players & Recorders
Rca record player is playing slowed down or sped up
Hi there
this sounds like the belt that drives the turntable itself is slipping you can normally access it by removing the securing clip by the centre spindle and then lift the turntable up and you should be able to see the belt give the belt a good clean with isopropyl alcohol refit and hey presto (if you still get slippage order a replacement belt )
Rgards Al "Alstech "
May 26, 2009 | RCA 200-Watt 5-CD Compact System Model...
Turntable won't turn
There is usually a cotter pin at the center of the platter around the spindle base. This can be removed with a screw driver using a twisting motion. There is a blades worth of space between the clip and the spindle base. Screw driver should be in vertical position. Sometimes the vinyl slip mat must be removed first. Watch that clip, cause it can go flyin. Once the clip is removed, the turntable should let go easily.
May 03, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Reattaching Belt to Two posts
I had the same problem... Here is what I did. As the previous post mentioned, remove the black plastic turntable platter. You now should see the loose belt. If the belt is still good, place it back on the underside of the platter. You will notice there are two opposing plastic pins located at the outer edge of the platter. Pull the belt over one of the pins. Place the platter over it's chrome spindle shaft, with the plastic pin facing the motor shaft. after the platter is in place (don't put the "e-clip" on just yet...) rotate the platter a couple of turns. This should do the trick. If not, keep trying. It worked for me on the first try. After the belt is back on, secure the platter with the e-clip and replace the black rubber mat. Viola!
Oct 13, 2007 | Philco (R) 841.205 CD Shelf System
Need a new clip
i am not sure if you have this store there but i live in halifax and the store called the running room usually carries stuff like that
Jul 24, 2007 | RCA Lyra RD2217 MP3 Player
Errors on loadind
Your cd-player fails to read the discs. assuming the disc isn't damaged your problem might result of many diffrent reasons, from dirty lens to bad mechanism, memory problem or bad circuit. You will need to have it checked by a professional technician.
Mar 16, 2006 | GPX CDP3104CK Personal CD Player
Errors
It could be just about anything: lens mechanism, lens, motor, power supply problems... post your question again, and qouting the error messages you're getting will help the users here narrow it down.
Mar 15, 2006 | GPX CDP3104CK Personal CD Player
GPX CDP3104CK Personal CD Player Logo
81 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
