Question about Pyle Pl1157rd Led Brake Lights Light Bulbs Pl1157rd
1995 buick regal custom brake lights don't work right.If you use the singnals they after that the brake lights work for a minute or two then not again
    Problem Solver:
  • 10 Answers
You may have grounded them out with the turn signals if not you may not be getting the required power for the light according to the manufacturer ,otherwise it possible they need a different power source from the stock oem power But all in all check the ground and make sure your getting 12 volts with a volt meter
Posted on Apr 24, 2009
Have a 1995 Buick Regal. Car stalls when braking at a stop sign or braking into a left or right turn.RPMs drop to 500 then stalls without warning.Car starts right up with no problem and runs great.
Do you hear a sucking noise from under the hood when you apply the brakes? You could have a bad brake booster venting too much engine vacuum when applying the brakes causing the engine to die.
Dec 17, 2015 | 1995 Buick Regal
Brake lights work but are very dim
It can be loose wiring or issue with bulb or the battery is weak or brake light socket getting short somewhere.Car lights getting dim,there are many such common issues noticed.I will share some familiar help links,related to your problem.
Click the link below:---2004 Dodge Ram: High Beam Light is DIM? http://technoanswers.blogspot.in/2012/04/2004-dodge-ram-high-beam-light-is-dim.html
----------Ford Odometer Dims intermittently http://schematicsdiagram.blogspot.in/2012/07/ford-odometer-dims-intermittently.html
---------Turn Signals Don't Work When Brakes Are Applied? http://schematicsdiagram.blogspot.in/2012/04/2005-gmc-envoy-turn-signals-dont-work.html
Brake light Switch Location? http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
----------- No brake lights on Buick? http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
----------- Brake lights not working on 1989 BUICK REGAL? http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
These will help.
Thanks.
Nov 06, 2012 | 1999 Ford Contour
1995 buick regal no brake lights no left turn signal
replace the turn signal wiring harness had the same problem with mine no brake lights
Mar 20, 2012 | 1995 Buick Regal
1995 buick regal turn signals not working
Do they not light up or do they light up and not blink? Do the brake lights work?
Nov 07, 2010 | 1995 Buick Regal
Rear brake lights don't work , but center brake light does.
brake lights won't work, but the center does ??? u need to change your turn signal switch which is in the steering wheel. i changed mine and it worked great .....
hope that helps
s2g1
Apr 22, 2010 | 1995 Buick Regal
'95 Buick Regal GS 3rd brake lights don't come on.
my 02 has 2 nuts in the trunk then it will lift out of the cat walk
Apr 19, 2010 | 1995 Buick Regal
Brake light doesnt work?
Don't take shortcuts with auto repairs. The work for now bulb may have caused a problem like a short. Check the brake light switch and test all brake light bulbs.
Jun 02, 2009 | 1995 Buick Regal
HAVE A 1995 BUICK REGAL WITH NO BRAKE LIGHT EVERYTHING WORK BUT NO BRAKE LIGHTS LIGHTSBULBS FUSES CHECK GOOD. HELP THANKS TOM
I had this same problem. I replaced the turn signal switch in the steering column and it worked great. To test for this, check your lights while wiggling your hazard light button and/or signal lever. When I pulled my hazard button forward, all my lights would come on.
Dec 12, 2008 | 1995 Buick Regal
Pyle Pl1157rd Led Brake Lights Light Bulbs Pl1157rd Logo
137 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
