Question about Lexmark X3470 All-In-One InkJet Printer
Use X3470 with print server
Just got a X3470 to replace a broken HP injet - its used by several people on a home network but I cant get the printer working other than directly, prnt server is a Dlink DP-30u. Any suggestions?
  • ianmckend Mar 09, 2009
    network works ok - I can see the print job on the print server but its just not getting to the printer - perhaps they as not talking the sme language?
  • 1,602 Answers
MOST OF THE TIME AND I MEAN 90% OF THE TIME IT IS THE CABLING AND CONNECTOR ARE THE PROBLEM AND THAT IS EASY TO FIX.
SOFTWARE ISSUES ARE EVEN HARDER TO SOLVE BUT BEFORE I SEND YOU DOWN THAT WAY HERE ARE SOME OPTIONS TO INVESTAGATE BEFORE MAKING ANY TYPE OF SOFTWARE CODE CHAGING. TRY THE FOLLOWING OPTIONS FIRST...............:
1 CHECK EACH COMPUTER BY GOING INTO CONTROL PANEL OPEN FOLDER CALLED NETWORKING AND SHARING CENTER.
2. NIC CARD INSTALLED IN THE COMPUTER AND GO TO DEVICE MANAGER AND TEST THE CARD, UPDATE THE DRIVERS AND MAKE SURE EVERY THING IS WORKING PROPERLY.
3. IF THE NIC CARDS ARE CONSIDERED A PLUG AND PLAY DEVICE YOU CAN GO TO
SYNC CENTER AND IT WILL CHECK EVERYTHING AND TEST THE EQUIPMENT FOR YOU, LIKW WIZERD WOULD DO.
4. GO TO SECURITY CENTER AND MAKE SURE THERE IS NO CONFLICKS WITH ANTI-VIRUS PROGRAMS *****************
ON ALL THE COMPUTERS YOU ARE HAVING NIC ISSUES ONLY************************
5. CONTROL PANEL OPEN UP WINDOWS DEFENDER CHECK FOR ANY TYPE OF MARKS THAT SHOULD NOT BE THERE, YOU ONLY WANT xxxxxxxxxxxxxGREEN -MARKS******* IN THESE IMPORTANT AREAS
6. GO INTO CONTROL PANEL AND OPEN FIREWALL, THE FIREWALL ONLY GREEN IN THIS AREA TOO.
NO YELLOW, ORANGE, RED MARKS.
IF YOU FIND ANY ERRORS CLICK ON THE ERROR AND GO ON LINE IF YOU CAN TO RESOLVE THE ISSUES BECAUSE THEY ARE GOING TO USE EVERY VENDER OUT THERE TO RESOLVE THE ISSUES WITH YOUR SYSTEMS.
7. FIND A KNOWN NIC CARD THAT WORKS AND CHECK EACH COMPUTER AND GET IT TO WORK THAN SET THE CARD UP TO THE SETTING OF THE CARD AS THE SAME AS THE TEST CARD IS SET TO. *********** I KNOW EACH NIC CARD HAS TO HAVE ITS OWN CODE IN ORDER TO WORK PROPERLY,..USE THE HIGH NUMBERS SO YOU WILL NOT HAVE ALOT OF ISSUES AND EERORS WITH YOUR NETWORK.
8. LAST THING CALL IN A NETWORK SPECAILIST OR ADMINSTATOR OF THE NETWORK.
I HOPE I HELPED YOU
RODGANDYSR
Posted on Mar 07, 2009
Hello I would like to buy a compatible print server for my hp officejet 4255 all in one, because I want to share it among several pc-desktops connected to a router in wi-fi. Netgear says they do not...
What you want is the HP 2101NW
Unfortunately, this product has been discontinued by HP themselves, but you may be able to find a store that has old stock, or find one on EBAY.
The easier solution is to share it across the network from a workstation that is always on, or make a print server workstation out of an old PC or laptop that will do nothing but share the printer across the network.
You can buy an older PC to use for this function cheaper in many cases than buying a standalone print server. I did this myself for ages using a laptop I picked up for $50. The laptop wasn't good for much more than a print server, but as a print server it worked flawlessly. The laptop would wirelessly connect to the network and was USB wired to the printer, which it shared across the network.
NOTE: you will be limited to PRINT ONLY under these situations.
If I recall correctly, the only way to have full functionality is with the 2101NW which as I said is now discontinued, but was an amazing product in it's day!
Jun 24, 2011 | HP OfficeJet 4255 All-In-One InkJet...
The printer (hp laserjet p2015) appears offline
Press and hol the green 'go' button until the lights flash, (about 4-5 seconds) and release the button,
Wait for the config pages to print out, and then check your network configuration, i.p address, Subnet mask and gateway.
If no network page prints out, you might have a dead Network Interface in the printer.
May 10, 2010 | HP LaserJet P2015dn Printer
I need to get a wpa passphrase how do i get 1
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have installed the DP-301U print server on my home network to print to an HP Laserjet 4050. When setting up the print server per instruction, I set my computer IP address to a static IP address. The...
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
Oct 20, 2009 | D-Link DP 301U (DP-301U) Print Server
Wireless Dell laptop can't 'find' HPDeskjet 5150 Printer
this printer is (as per HP specs) only connected via USB or Wlan Print server.
Check connection using USB cable and be sure Printer driver are correctly working.
Check on Router your Print server IP address (Lock it out of DHCP)
Put both PRT and PC on same home network (normally HOME or MSWORK)
Put Printer server IP address into your printer properties/port tab/ IP.
OR check if you see your printer server in your Windows network/home network
Jan 11, 2009 | Computers & Internet
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Can I connect the printer directly to my laptop using ethernet cable
Hi! If the computer is connected to an HP All-in-One on a network, you can access the Embedded Web Server that resides in the HP All-in-One. The Embedded Web Server is a web-based user interface that provides some options not available on the HP All-in-One control panel, including advanced network security options. The Embedded Web Server also enables you to monitor status and order printer supplies. For information on how to use the features available in the Embedded Web Server, see the onscreen help within the Embedded Web Server. To access Embedded Web Server help, open the Embedded Web Server, then click the Help link under Other Links on the Embedded Web Server Home tab. NOTE: Only use the Embedded Web Server to change network settings if you cannot access the HP All-in-One control panel, or you need to change an advanced option not available on the control panel. Access the Embedded Web Server Use the following instructions to access the Embedded Web Server. You can only access the Embedded Web Server on a computer that is connected to an HP All-in-One on a network.
  1. Press Setup on the HP All-in-One.
  2. Press c00706174.gif until Network is highlighted, then press OK . The Network Menu displays.
  3. Select View Network Settings menu, then press OK .
  4. Select Print Network Configuration Page , then press OK . A configuration page prints, including the IP address. You will use the IP address in the next step.
  5. In the Address box in the Web browser on the computer, type the IP address of the HP All-in-One, as shown on the network configuration page. For example, http://192.168.1.101 . The Embedded Web Server Home page displays, showing information for the HP All-in-One. NOTE: If you are using a proxy server in your browser, you might need to disable it to access the Embedded Web Server.
  6. If you need to change the language displayed in the Embedded Web Server, do the following:
    1. Click the Settings tab.
    2. Click Select Language in the Settings navigation menu.
    3. In the Select Language list, click the appropriate language.
    4. Click Apply .
  7. Click the Home tab to access device and network information, or click the Networking tab to access more network information or to modify network information.
  8. Make any configuration changes.
  9. Close the Embedded Web Server.
Good Luck!
Oct 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Hp 1280 injet
The vista network setup not properly set.
Feb 21, 2008 | HP DeskJet 1280 InkJet Printer
Wireless laptop not printing
Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
Jan 20, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
What brand of print server would be compatible with a linksys broadband router and the HP printer?
You asked for any advice. If you want to use a server, you must already have at least a home network set up (it could be wireless or hard-wired). Yes, stand-alone "print servers" are notorious for only supporting certain printers. If you don't know this before you buy, you may find yourself returning your print server to the store. However, instead of a standalone print server, have you considered setting up one of the computers in your network as a "print server"? That's the way it used to be done. That's the way my own network is set up. You would set up your multifunction printer as connected directly to one of the computers in your network. Enable "printer sharing" on that computer. Then do the following on all other computers in the network for which you desire access to the printer: Add a network printer. If asked for drivers, get them off the printer's installation CD.
Mar 30, 2007 | HP PSC 1410v All-in-One Printer
Lexmark X3470 All-In-One InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
