Question about Philips 46PP9302 46" Rear Projection Television
Picture goes out
Some times the picture flickers then goes out and other times it just goes out ,some times itcomes back on and other times I have to shut it off for a while before it will come back on. Repairman had it 3 weeks and said he found no problem. Same day he returned it it got worse.HELP!
  • 294 Answers
CHECK THE COOLING FAN ON THE BACK TO MAKE SURE ITS WORKING AND NOT DIRTY, ALSO TRY PLUGGING IT INTO A DIFFRENT OUTLET OR NOT INTO A POWER SURGE PROTECTOR TRY STRAIGHT INTO A OUTLET
Posted on Mar 07, 2009
How to remove back picture flickers then goes
Hi ignafam,
Sorry for the late reply, I'm offline upon purchasing my service.
I have some question so that I can give you an accurate solution regarding on your problem.
1. Exact model no. of your unit - this is located on the back cover, manual, or on the receipt.
2. Does the unit has sound, before it goes blank?
3. Does the unit goes black or white screen?
4. Does the symptoms remain the same in all inputs(when watching TV, DVD, game console, etc)?
Jdvillanueva
Oct 14, 2011 | Vizio 42 in. LCD TV
Backlight flickers
The bacllight will need to be replaced before it goes out or you could end up replacing the inveter and backlight at the same time.
thanks I do hope this was Very Helpful to you.
Dec 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
My 14 month old, 32 inch Samsung flat screen tv ''flickers'' The cable went 'out' 3 or more times and when returning the TV started flickering. We have unplugged & plugged it back in several times, but...
Check if this occurs regardless what the source of the signal, whether it is DVD or cable or a playstation. You can also check if the Menu flickers as well. If the menu does not flicker along with the picture it could be a problem with the source, probably your with the cable box or the port where it goes to on your tv
Aug 05, 2009 | Televison & Video
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
Picture Flickering
The sony tuners have been known to get intermittent, it might be a bad ground where the tuner connects to the main chasis, If the problem is in the tuner itself it will be most difficult to resolve since the connections are so small and compacted together.
Good luck
Apr 19, 2009 | Televison & Video
Picture is flickering then going off
tae your tv to a w/shop tech
your tv has a dry joint or one of the active components is heating up
or a supply is varing
Mar 06, 2009 | Bush 2871NTX 28" TV
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
PIcture Flickering
you may have a convergence problem. need to replace the stk 392-040 2 eq..
Jul 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
