Question about GE DCVH515EFWW Electric Dryer
I have a GE electric dryer, Model DCVH515EFOWW the dryer works fine on "Air Fluff" but and motor runs fine. When put to a heating cycle the dryer starts runs for up to 2 to 3 minutes electric dryer element starts to produce heat and the vent is blowing warm air with no restrictions, then it shuts down waits for 2 minutes and starts all over again. The upper thermostat is staying closed, but I don't know what the resistance levels of the thermistors are to check them? Any ideas?
  • Anonymous Mar 08, 2009
    Serieal number is 2H775961A which it looks to be about 2005
  • rfrusher May 11, 2010
    HOW OLD IS THE DRYER?
  • 87 Answers
SOURCE: Dryer will not start. Ge DX4500EAoWW
You may have a bad timer: Also, there may be a separate thermal fuse for the motor, usually an inch long white plastic one attached to the blower housing.
Posted on Jun 08, 2007
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
buffalonyman
  • 1865 Answers
SOURCE: Model DBSR453GB1WW bought around 2004/2005 - Dryer runs but will not heat up?
This model uses an ignitor, you can replace the ignitor for about $80
Posted on May 12, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
mikes112
  • 56 Answers
SOURCE: GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Posted on Mar 23, 2010
GE - Hotpoint Dryer Model # QUXR453EV2WW (2001)blows breaker what might it be
Shorted heating element. Fluff cycle does not use heat.
Sep 18, 2016 | GE Dryers
Ge front loader dcvh515efoww - dryer shuts off when put on heating cycle
Did you pull the dryer out or forward sounds like you may have pinched the exhaust which restricts air flow exiting the unit this will cause it to heat briefly shut down heat shut down and continue this cycle the fact that it worked before makes me think it something simple it will not tumble in any cycle if door switch not installed correctly.
Mar 21, 2014 | GE Dryers
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
What do the "T" error codes mean in regards to GE electric dryer model # DCVH515EFOWW
YOU must see you instruction manual section troubleshooting and Fix it.
if you do not have download the instruction manual from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 19, 2012 | GE Dryers
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Timer / heater malfunction
The heater coils or going bad. It has two wire rings that heat up. One are two has burned out.
Jan 17, 2009 | GE DCSR483EA Electric Dryer
GE DCVH515EFWW Electric Dryer Logo
160 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
