Question about Whirlpool LEQ8000JQ Electric Dryer
Whiirlpool electric dryer leq 8000 jq1 (wont start)
  • 13,433 Answers
Please have a look at this list of possible solutions to your dryer not working at all.
http://www.repairclinic.com/0088_8_1.asp#Level1_1
Posted on Mar 07, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Please check the power cable at the back of the dryer.
  • Rylee Smith
    Rylee Smith Mar 07, 2009
    Please check for any blown fuses.If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. If the fuse is fine then check this link to check the possible problems and their solutions.
    Whirlpool electric dryer
    Please revert for any clarifications.
    Thanks
    Rylee
Dryer shuts off after 5 seconds then beeps 3 times
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Apr 03, 2015 | Frigidaire FARE1011MW Affinity High...
Kenmore 8000 series electric front load dryer vibrating
Check the drum rollers. Sounds like one is bad.
Dec 07, 2012 | Dryers
The motor on my dryer is working but the barrel is not spinning. The model is LEQ 9858 PW1
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 16, 2011 | Whirlpool Dryers
Model 3HLER 5437 JQ1 - 230/240 15A 50Hz Plug (fitted with13a Fuse) has overheated to the point of scorching & melting (with the machine still running). Please advise likely cause &...
The heat sensor is stuck in the open position........The sensor will click when a lighter is held close to it for a while to shut down the elements which are providing heat for drying...........Yours is staying open causing extensive heat...........Hope this helps.
Apr 20, 2011 | Whirlpool Dryers
Dryer stoped working mid cycle like it lost power and wont restart. Check breaker and electric allready.
maybe your timer motor, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 25, 2010 | Maytag HYE3658AY Electric Dryer
Kenmore electric dryer stopped and wont start when button
Make sure there is 240vac then check the door switch, the start switch. Beyond the obviouse it is basic troubleshooting to work down to the failed component. Eric
Aug 08, 2009 | Kenmore 62602 Electric Dryer
Location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
Apr 20, 2009 | Whirlpool LEQ9858L Electric Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
