Question about Toshiba Satellite A135-S4407 Notebook
No response from Toshiba Satellite A135-S4407
I'm having trouble with my Toshiba A135-S4407. I have no display. I tried using an external monitor because I thought the inverter was bad. No dice. I installed another hard drive and still no response. I can hear the hard drive start for a second or two and then nothing. Also, the caps light does not work since this problem started. Any suggestions for a newb? Is there a possibility the mother board is bad? Thanks in advance!!
  • Anonymous Mar 20, 2014
    flash
    driver
  • 4 Answers
Yes, there is a very good chance your motherboard is bad. If you haven't already, please remove one of your two memory chips from the memory bank ( bottom of the laptop ), and try powering up again. Sometimes a bad or loose memory chip can cause a no post issue. If you're still having the same problem, then the only other piece of hardware in your laptop aside from the motherboard that can cause "no video" would be the cpu. Requires a complete tear down of laptop and a known good cpu to test. However, from my personal experiences the A100 series motherboards are notorious for having motherboard problems so it's most likely the motherboard. I can repair your laptop at a great price. Email for info : 586techtools@gmail.com
Posted on Apr 25, 2009
No screen display
Your LCD inverter circuit or Backlight lamp may have died. The Backlight lamp is a CCl (Cold Cathode Lamp) closely resembling a thin fluorescent light bulb.
If you can replace this lamp, the typical cost for this component is $9-$15.
First thing to try is to plug in a standard (RGB analog) monitor into the system's 15-pin external monitor port to see if the system is booting to MSWindows (or not).
If the OS is failing to boot, at least the external monitor may allow you see what the ROM BIOS is doing, and possibly run BIOS-based system diagnostic software.
If the OS is booting properly, you can use the notebook PC with the external monitor (as a workaround), until you can repair the console screen, or replace the computer entirely.
If you are able to access the system via the external monitor, you may want to take the opportunity to backup any important data (iTune downloads/income tax forms/original manuscripts for novellas/MRI scans,etc.) on the Toshiba A135 to an external hard drive, large flash drive or CD-RW discs.
Here's a good laptop lamp/inverter solution posted to FixYa:
http://www.fixya.com/support/t2358968-laptop_screen
Dec 14, 2011 | Toshiba Satellite A135-S4407 Notebook
I have a Toshiba A135-S4407. No power
The problem might be from your Processor or probably change the memory module once the problem persist then your processor is the problem and later restart your system ok
Feb 20, 2010 | Toshiba Satellite A135-S4407 Notebook
Toshiba Satellite A135-S2276 PC Display screen
Maybe it is just disabled they can be set to... Screen on Laptop ONLY... External Screen ONLY, Both Screens on together. Try to find the keys that toggle those modes? in your manual.
Feb 03, 2010 | Toshiba Satellite A135-S2276 Notebook
I can't turn on my laptop
Try charging it for an hour or so. And then try, else reboot it.
Sep 30, 2009 | Toshiba Satellite A135-S4407 Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Fogot password
u need reload the voice that is the best or if u try any third party software u could not get any warenty
Jan 31, 2009 | Toshiba Satellite A135-S2276 Notebook
Have toshiba satellite a130/a135 laptop screen red then goes blank
Try hooking up a external monitor. If you get video on the monitor and not the LCD, then your LCD may be in trouble.
If you don't get video on the external monitor, then your video card is gone.
Aug 23, 2008 | Computers & Internet
Laptop powers up buy displays nothing
Can you plug the laptop up to an external monitor and keyboard, and test it that way?
Is it possible that the laptop is currently set to use the external monitor instead of the default one?
Mar 29, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4407 Notebook Logo
311 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
