Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport. I am getting a f33 error code.
My machine is displaying an F33 error code. What does this mean and how do I fix this. I can not pay for a repair man. PLEASE HELP
    President:
  • Whirlpool Master
  • 2,651 Answers
I would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
Posted on Mar 12, 2009
  • Clifford Abraham Dec 23, 2012
    I replaced the hose twice. The reason I had to do it twice is because the inside diameter of the hose has to be the exact size or the volume of air going through it will not build the required pressure to activate pressure switch
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Everytime i try to run a load of wash i get a F33 error - what can i do?
Please clarify the Model and Make of your Washer.
The F33 error for Whirlpool: The "F33" error code means that the washer has encountered a system error with the pump drive. The parts should be working fine; it is just the connection that caused the problem.
Check connectors on central control board.
Mar 09, 2011 | Washing Machines
I have error code f33 .What dose it mean and how do i fix it
F33 System leak
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Solution
  1. Make sure the hot and cold water lines are on and pressurized.
  2. Check for cracks or holes in the washer tub and pressure switch hose.
  3. Replace components if necessary. The pressure switch hose can have a pinhole in it and throw this code.
Feb 27, 2011 | Whirlpool WFW8300SW
What does F33 mean- its the code on my front loader washing machine
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
I have an f33 error code on the whirlpool duet front loader please help me to fix this.
F33 = PUMP DRIVE SYSTEM ERROR
When the connection between pump and the Central Control Unit (CCU) is lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Faulty CCU < call for service >
Nov 10, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Error code f33 on an he4t
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 11, 2009 | Kenmore Washing Machines
F33 displayed in whirlpool duetsport frontloading washer
F33 Leak. If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. Check your inlet valves for block, where the water comes to machine OR
Press ‘pause’ and ‘cancel’ twice to clear the display. Mains off the wall.
1. Check for crack or holes in the washer tub and pressure switch hose, which runs from the
bottom to the pressure switch.
2. Replace components if necessary.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error Code F33 after new bellow put in. How can I fix it?
Just fixed my F33 error code for GHW9400. This code is for the pressure switch HOSE. Mine had a small pin hole. Cost:: the dealer gave me a free new hose. Remove the top and back. In the top right hand corner (at the back of machine) you will see a small hose attached to the pressure switch box. It is small black& 3/8" and about 2 1/2 ft long coming out of the bottom.. Mine was not attached with anything. Pull off at the top and bottom. Look for even the tiniest hole. Hose probably can't cost a couple of dollers.
Replace and just finished my first error free load. It may be causing your leak too.
Jan 10, 2009 | Whirlpool GHW9400 Front Load Washer
F33 error code
F33 System leak If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
Jun 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he4t
really need the whole model # ?
1 pressure switch
2 flowmeter
3 CCU
4 hose
he F33 means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
May 20, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
4,369 people viewed this question
Dan Webster
Dan Webster
Sal De
