Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint motor problem after renewing drum bearings!
I, ok i have just renewed my hotpoint washers drum bearings, put it all back togther drum turns lovely no leaks, but now the motor wont agitate but spins fine exept on the very fast spin (1400) the motor arc`s and trips the house rcd! it was fine before i stripped it down to do the bearings, what have i done!! (i left the motor attached to the plastic drum when i did the bearings could i have disturbed something in the motor?)
  • Anonymous Mar 07, 2009
    ok i thought that, but it was working fine brfore i fixed the bearings, thats what i dont get, and on the spin cycle the motor works fine, its like it loses power when on wash cycle?
  • dave2812 Mar 07, 2009
    Scholar:
  • 86 Answers
Hi dave, Its nothing you have done! It will need the carbon brushes changed in the motor as they have got low. The arcing is caused by the brushes not touching the com properly. Just change them and it will be all good.....
Posted on Mar 07, 2009
  • Kris Seymour Mar 09, 2009
    Ok well then if that the case then you might have the wash windings in the motor on there way out! Then you will need to replace the motor! Check the conections on the heater as this can cause a low neutral return on the motor side.
Motor is running but won't agitate and belt is on ? I can hear the motor humming and it will fill up but it wont agitate.
Check drum turning by hand ok not sticky sounds like could be motor if it hums and no turn..
Oct 18, 2014 | Hotpoint Washing Machines
Hotpoint 1200 wd62n banging noise when loaded but ok when its empty ?
There are many reasons that this could be noisy...
When you turn the drum (quickly) when it's empty does it rumble? Bearings, drum support or motor bearings.
If it sounds like a pneumatic drill when filled and spinning it could be drum support, bearings, balance weight or suspension.
These are not an exhaustive list but the usual suspects.
Jun 02, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Wont spin
Possible fault with the drive system if the motor is working without any transmission. You need to check for slippages in the drive. It can also be due to bearing problems or the main shaft being stuck in the drum.
click this link:Bearing replacement
Jan 01, 2013 | Speed Queen AWS17NW Top Load Washer
Noise when agitateing wash only
Remove the belt, and spin drum by hand from inside, there should be little or no noise, if there is then it is possible the drum bearings are failing.
I f no noise, but there is when you put belt back on, then possibly bearing in motor noisy
Mar 06, 2010 | Hotpoint WMA66 Front Load Washer
Hotpoint WF220P has become very noisy during spin, especially at high revs. Can it be worn brushes or motor, or bearings? Otherwise all is OK.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Nov 02, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Washing machiene drum won't turn
it sounds like you've got an item of clothing jammed between the inner and outer drum
Jun 22, 2009 | Indesit W 123 Front Load Washer
Wt960 drum judders and wont turn smoothly
not enough info but could be one of two things "brushes or bearings" the fits and starts says brushes need changing in the motor. If its bearings put your hand on the top of the drum and lift slightly upwards if there's play in it then it's the bearings
Jan 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
The washer works fine aparts from the drum wont turn at all.
there is a motor speed control board in the back of the washer. if your facing the back of the washer its on the bottom left side. there is a fuse on that board that will stop the motor from running
Nov 22, 2007 | Hotpoint First Edition FEW10P Front Load...
Washer wont spin belt came off put it back and tested on a spin but then it started making weird noises so we stopped it. turned drum manually but then drum jammed going one way but not the other
two possible causes. first - foreign object stuck between tub and drum. take heater out and you can peer into the gap between tub and drum second - bearings collapsed and im afraid this is the most likely cause. if memory serves me right, hotpoint supply a replacement tub and drum assembly at vast cost. lots of problems with bearings on the wma series
May 23, 2007 | Hotpoint WMA50 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
149 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
