Question about Mk Diamond MK 101Pro Tile Saw
Vibration then switch stopped working and then started sparking
A while ago my saw started vibrating really badly then about a week ago the switch stopped working. when you tapped on it it would work temporarily. so then I was plugging it in to turn it off and on when it started to spark and actually melted my extension chord. any ideas?
  • 29 Answers
They make foot pedals, and,you should be able to get them t a good tile tile shop,they cost about 75 bucks,i have 2 of them and use them daily.as for the vibration, it might of been the blade guard wing nut they always come loose. now you are way to late to fix those problems,take it to a tool repair shop. bummer dude, you should of bought a target or a pearl
Posted on Mar 12, 2009
  • chad bigger Mar 26, 2009
    actually mk is a dam good saw, you probably fried all electrical parts, i've seen those motors catch fire, the guy sprayed wd40 on a saw that had similar problem. take it to a shop
2011 jeep compass vibrations when stoppped in drive
This worked for me
Hey all. I had the same issue with my wifes 2010 Compass. I figured it was the same thing as most everyone else, bad mount or torque converter. I saw a post about the rubber stops under the hood and adjusting them didnt really help. I checked the top/side mount, lower front mount and lower rear mount and they were all intact. I figured it might just need a tune up so I decuded to change the oil, 4 spark plugs, and the air filter. One of those worked!! Honestly I think it was the air filter. it was very dirty. I suspect that the car was struggling to get enough air and it was causing the car to shake more than normal. Anyways I hope this helps someone. Good luck!!
Jan 08, 2012 | 2011 Jeep Compass
Bad vibration and noise from saw
Are you sure blade is straight, and mounted on arbor correctly? that's the first thing to check. Or remove blade and 2 arbor plate's and run saw. If you have a vibration after that you have a bearing problem.( rear bearings go bad on these saw's) other they are the best saw for the price. We have about 50 of the 4000 model. hope that help's Never had a vib problem.
Jun 01, 2010 | Bosch 4100 10" Worksite Table Saw
93 Lumina 6cyl 3.1 engine shaking @ overdrive gear
check your camshaft and crankshaft sensors. When defective, it may cause stalls, misfires, loss of power. Also have check the engine for vacuum leaks. Hopefully this helps!!
Apr 14, 2010 | 1993 Chevrolet Lumina
08 accord ex-v6 auto. engine vibration @ idle in park or (gear at stop) when engine is cold to warm until it fully warms. dealer states it's normal. dealer showed me another accord with similar shake.???...
I've got an 08 4cyl and it doesn't really have the vibration unless its really cold. Usually if I give it about 30 seconds...when the rpms start to come down, its barely noticeable.
Jun 24, 2009 | 2006 Honda Accord
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Brake pedal vibration
Sounds like sticky caliper for one reason or another which has probably warped rotor(s). When that vibration occurs & you pull over to stop it, carefully touch rim to see if hot, or hotter than other side, which is a good indicator to tell you which one is sticking. Don't just change one though, do both.
that is provided it's just not a case of lubricating sliders etc, to get calipers moving freely.
Jun 02, 2009 | 1999 Honda Passport
Bad vibration engine trans under load
seems your problem is within your clutch,defective part,usually a defective release bearing will cause gear shifter and pedal vibration but not as bad as yours,but by pressing on clutch pedal vibration stops,point to clutch!
Apr 07, 2009 | 2002 Dodge Neon
Why does my car vibrate and noisy at red light and stop sign
Maybe it's the transmission itself. check it.
Jun 17, 2008 | 2002 Kia Rio
Mk Diamond MK 101Pro Tile Saw Logo
159 people viewed this question
Top Mk Diamond Saws Experts
Tom Chichester
ray gallant
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
