Home | Danby | DMW1146SS Stainless Steel 1000 Watts Mic... | Second heat limiting fus...
Danby DMW1146SS Stainless Steel 1000 Watts Microwave Oven
Problem for Danby DMW1146SS Stainless Steel 1000 Watts Microwave Oven
Second heat limiting fuse is blown. require the
By ron_s1 on Mar 07, 2009
second heat limiting fuse is blown. require the temp.specs to replace it. only indication on burnt out unit is 105 LC.
Solution #1
posted on Mar 07, 2009
Not Rated)
rfrusher
Rank: Master
Rating: 77%, 19 votes
TAKE THE MANUFACTURER AND MODEL NUMBER FROM THE UNIT.THEN TAKE THAT INFORMATION AND THE FUSE TO YOUR LOCAL APPLIANCE PARTS STORE.THEY CAN
MATCH IT UP FOR YOU.YOU CAN ALSO USE THE INTERNET TO DO IT YOURSELF.JUST TYPE IN THE NAME AND MODEL # OF THE UNIT.
Was this helpful?
Yes
No
Popular Solutions for Danby DMW1146SS Stainless
Questions and Unsolved Problems for Danby DMW1146SS Stainless
Do you recommend Danby DMW1146SS Stainless Steel 1000 Watts Microwave Oven?
Answer
Answer
Hi, I have a Danby 1145ss Stainless steel Microwave that is not working at all. No noises, no... (More)
Answer
Microwave will stop working after 10 minutes and shut off all power to itself. Then after a five... (More)
Answer
oven seems warm to the touch, but not hot after a 2 minute run. Left side is cool to the touch but... (More)
Answer
Program does light anymore and plate turns continuously. I bought it on February 8, 2009 ($109.96)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DMW1146SS Stainless...:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 663
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
