Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Problem with installing xp
I can't install xp in my lap top .while installing xp,after loading files the system stops with blue screen .can u suggest a solution for this?
After completion you set the bios to defaults and reboot the system later you remove the cd
try this
Posted on Mar 08, 2009
I want to install windows xp on dell inspiron mini 1018 but i am not able to install.some blue screen comes.please help
turn off your antivirus before you try to revert back to xp. your system antivirus might see this as an attack on your windows 7,thus it won't allow you to install a different system.
Feb 25, 2012 | Dell Inspiron Mini 10 Netbook
When i start win xp setup from wintousb software bcz i want to install win by usb after loading win files it gives blue death screen technical info:...
try going into the system setup or bios screen and see if you can find a setting for SATA Operation or SATA Mode for the hard drive. if you can find this, select ATA or AHCI and test the installation again. hope this helps.
Apr 16, 2011 | Computers & Internet
Cannot install windows xp in CQ40-317tu
hi aman this is saurabh ....i can solve ur problem...let me tell u that tere has been a colobration between microsoft and hp that hp will not install any hard disk drivers of any old operating system that is basically xp...thats why when u try to install xp u get an fatal error of hardidsk error.....so i have made a cd in which the drivers r prem loaded and it will run in ur compaq presario.......so u call me i will send u the cd...my no is 09896038291
Sep 30, 2009 | Computers & Internet
I recently tried to install a new WD320Gb HD and windows XP won't load. I loaded it to the drive from another computer and Windows won't successfully boot up. I get a Stop: 0x0000076B (0xF7946640,...
You installed the 320GB drive into another system & installed windows XP. Than removed the drive & installed it into another computer!
All of windows internal drivers for the first install will not function in the second. (Windows XP is going nuts).
You have to do a fresh install while in the system you want to keep the drive in. This is why your getting the stop errors & blue screens.
You must have a reason of why you did not install the 320GB drive into the second computer for the XP installation?
Care to provide the why?
Mike
Apr 26, 2009 | Biostar M7NCD Pro Motherboard
Problem with instaling windows xp
I got your problem hunny, for properly installation u have to first format the windows and shut down the computer take a new cd of windows check your CD ROM is OK or Not then Install the windows if any new hardware u attached before pull out that and install the windows may God your problem will be solved if got your solution plz reply me .
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
Lap top dell inspiron 6400, cant get into windows,
Have you tried doing a winXP repair:
XP repair
When you boot with the Dell Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If the repair does not fix it :
If you have documents you need,you would have to set the hard drive in an enclosure and copy the files over. Then you can run the Dell recovery disk . This will set it up as when it came from Dell.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 22, 2009 | Dell Inspiron 6400 Notebook
Toshiba (lap top) satellite M50 has no sound after antivirus scan
FIRST, FOLLOW THIS LINK: http://driverscollection.com/?file_id=33319
Second:
Type in the code and click Download File, scroll down a bit... there should be a blue link that says "Direct Link" Click the link. When the box pops up, Click SAVE. Make sure the "CLOSE THIS DIALOG BOX WHEN DOWNLOAD IS COMPLETE" is UNCHECKED. It may say something similar depending on XP or Vista. After the file is done click "OPEN" Afterwards double click the folder "SOUND DRIVERS" and then click a file named "SETUP.EXE" Note: There may be several files saying SETUP, try them all until a box informs you that you are installing the driver. Follow on screen instructions, and then your on your way to having a sound of a time with your Toshiba. If you have more questions please email me @ ThinkingComputers@yahoo.com . Thanks, James
Dec 31, 2008 | Toshiba Satellite M50 Notebook
Can not install win xp on laptop compaq vt 3717 after cd driver loading files, windows installing stop on blue screen. ... said ' windows stop installing to prevent damage on your ..." my installing cd...
make sure your computer has not over heated. place your computer on a flat surface where air can circulate properly and restart installing the operating system.
Dec 22, 2008 | Compaq Presario Notebook
Wipe hard drive
under the laptop xp home sticker.
have u backed up personal files ? pics docs music ?
turn pc on .repeatedly tap F12 then put xp cd in it. then choose cdrom. then it will boot to a blue screen. loading stuff on bottom 2 minutes.then 2 options repair console or install windows. choose second. then F8 i agree to licensing terms and then drive is listed.. at that point u can delete and create partition then it will ask to format i do quick. then rest is easy.
Aug 01, 2008 | Dell (0K724) for Inspiron 8100 40 GB Hard...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
