Question about Hitachi Tools & Hardware - Others
I have a Hitachi NV 45AB roofing nailer that is leaking a lot of air from the exhaust hole. I just replaced all of the o rings in the nailer and it did not help anything. Could this be a bad exhaust valve?
  • 2,176 Answers
You replaced all the orings and I take it that you lubed them a little with a light grease. By exhaust valve I assume you mean the plate on top and if so it could be a couple things does the air leak out when you connect the hose and don't do anything if so if you have a dead blow hammer try "tapping" on the top cover with the air connected, some times when replacing the rings the cylinder doesn't seat right away. If it leaks when you depress trigger then I would look for a cut o ring. Let me know and we can fo further
Posted on Mar 11, 2009
Hitachi 45ab blowing air out of trigger
If air leaks thru trigger as soon as you connect airline, replace the vinyl ball under the trigger stem. If air leaks when you depress the trigger, replace the small oring on the trigger stem. If air leaks slightly from plunger in front of the trigger valve, problem is inside of the gun. Remove the head and pull the large circular plate. Replace the large outer oring. Good luck
Feb 10, 2014 | Hitachi NV45AB2 Roofing Coil Nailer
I have a nv45ab roofing nailgun & it blows air out of exhaust on top any sug.
Hitachi nailers use an unusual design of actually moving the cylinder to fire instead of moving the headvalve. If the cylinder gets stuck in the open position (down), air will leak out of the head. To reset the cylinder, remove the nails and connect air supply. With air connected, lightly rap the head of the nailer against coiled air hose or soft rubber (too hard of a hit could damage the head). If after a couple of hits air still leaks, remove head and check headvalve for cracks. Replace as needed. If headvalve rubber looks ok, remove cylinder and clean/lube. If cylinder has fine scratches where orings make contact, sand smooth with 400 grit sandpaper. Lube with silicone paste, white grease or nailer oil.
Jul 29, 2011 | Hitachi Tools & Hardware - Others
Hello... I have a Hitachi NV45AB2 Roof Nailer. I have just completed a service on this unit with the 18001 O-Ring Kit. Everything looked good after cleaning and inspection. Problem is that I now have...
you can first try "tapping" on the cap with a soft hammer while air plugged in to seat the cylinder and if the air doesn't go away then you might have pinched an o ring while assembling. Also while assembling did you lube the o rings so that they slide and don't roll out of the grooves. Let me know if you need more assistance.
Apr 04, 2011 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi roofing nailer leaks air out the back after falling off roof, I have 5 of them all with the same problem. any ideas?
SOLVED! I replaced all the o rings put it together and air jus blew out the exhaust port. I made the mistake of pushing Piston plunger cylinder into the gun till it seated. this left a gap between the head and cylinder. I took the gun apart, removed the cylinder, an reinstalled it only far enough to seat past the o ring gasket. I then installed the head and let the head seat the cylinder as I tightened the screws. this worked on two guns with the same problem. Jn 3:17
Dec 11, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
The nailer piston on my hitachi roof gun stays out and will only fire 1 out of 15 times. i've tried oiling it, and hear no gasket leaks. what could it be ? dan.......
There are o-rings in the gun that route air around the cylinder to push the driver back up. One or more of these o-rings are worn or broken. You can get it fixed at a service center or you can go to sites like www.ereplacementparts.com to find a breakdown of your gun and order the parts. Unfortunately Hitachi doesn't make all in one repair kits and if you replace one, replace all of the o-rings.
Sep 13, 2010 | Hitachi 1 - 3/4" Coil Roofing Nailer
Air leaking aroung the trigger assembly from my Hitachi NR83A
if you took the trigger apart the part that you unscrew has a nylon ball and a black rubber ring you should check them and make sure that you didn't loose them when you took it apart,if they are there, then you need to service the gun, and after you clean all the moving part and you put it back together, it may still leak from the top,Take a rubber hammer and give it a good hit,now not to hard, and it should seal
Apr 27, 2010 | Hitachi NV45AB2S Coil Roofing Nailer
My nailer leaks air out the back my,roofing nailer wont hold any air
Hitachi nailers are built on very close tolerences. Dirt /grit will prevent cylinder from resetting causing air to leak out of top of gun. You can force a reset by striking the gun head first against a rubber mat. Only one or two hits because you could damage the head. If the gun does not reset you will have to take apart and clean out grit and replace orings as needed. Good Luck and post again if you have other questions.
Mar 10, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi NV45AB coil nail gun is leaking air from top of gun
the top!! o-ring inside of thr top plate is bad you need to remove the plate /dissasemble and replace the o-ring
Jan 21, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
My brand new hitachi NV45AB2 roofing nailer leaks air through the trigger when it is half depressed. I purchased one and returned it only to find the new one I recieved to replace it does the same thing....
Take off the back cover and make sure it's not too dry inside. Spray the inside with some WD40. You can take off the top cover. Pop the piston, cylinder, and head valve out, making sure all the seals and rings are seated correctly.Sounds like the piston is momentarily sticking. Does it shoot at all? Lemme know. Please rate me
Jun 03, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Rebuilt nail gun and now it just blows air out the exhaust port
This probably is the problem,
The cylinder that the piston moves up and down inside is probably to low, and not making contact with the rubber piece in the head cap.
The cylinder has a spring that allows for movement up and down, take a pliers and gently pull up the cylinder if it does not move freely on its own. It will stop when it reaches the cylinder plate ( the part with 2 screw holes for easy removal). Be careful not to mar the cylinder though.
When reassembling the cylinder should make contact with the head cap. Hope that works!
Apr 23, 2009 | Hitachi NV45AB2S Coil Roofing Nailer
Tools & Hardware - Others Logo
345 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
