Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
My thermador stove fan keeps going up and down cvs45r
Can i fix this?
  • 15,935 Answers
No
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Downdraft up and down
Hi do you mean the air is increasing and decreasing on its own
Feb 22, 2008 | Thermador CVS30R Kitchen Hood
Thermador CVS36R Cook'n'vent vent won't go down and fan stopped workin
You probably will find that the vent is clogged with grease. A switch device works with the vent so the fan operates only when the vent is open and does not operate when the vent is closed. Things should get back to normal after a thorough cleaning unless the fan is defective and won't operate at all.
Sep 03, 2012 | Thermador CVS236 36" Cook 'n' Vent System...
Thermador gas stove top is clicking when not on
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 21, 2011 | Thermador SGS36GS Gas Cooktop
Thermador cook n vent stuck in the up position. We have a thermador cook n vent. We had it running for about an hour. We turned the fan off but now it is stuck in the up position and will not go down. ...
replace the switch if the switch is going on and up position and not in down position the you should replace the switch for this part you can order it from thermador if they still stock the piece hope this helps
Aug 11, 2010 | Thermador UCV36A 36" Universal Cook 'n'...
Oven and broiler will not stay on.lights blink
I performed this exact same repair of a Thermador Model P366CS/03 on Thanksgiving Day 2017.
It seems a bit of grease had dripped down onto the microswitch with the sail on it. The grease was enough to prevent the switch from actuating. The thing is held down with two 4-40 screws and loose nuts. Be careful not to drop the screws into the range.
Now the problem I had was getting into the top of the stove. If the burner venturies are the least bit corroded, it's very difficult to get into the top level to gain access to the switch.
Nov 03, 2009 | Thermador PG486GEBS Stainless Steel...
Flashing Lights on Thermador Oven/Range
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Jan 31, 2009 | Thermador PGR366 Gas Kitchen Range
Could you tell me what year this model thermador gas top 6 burner
Thermador PRG stove is build between 2001-2003, $5, 000 new.
depends on the condition of the stove, and the oven. of cause, it is hard to say how much without testing it out. It is like buying a car. need test drive.
Jan 06, 2009 | Thermador PGR366 Gas Kitchen Range
Very Smelly Oven despite frequent cleaning (3 hours each time)
gee what is the blue liner material
is it a special metal coating?
internet link suggests these ovens are lemons
Top 436 Complaints and Reviews about Thermador - Consumer Affairs
https://www.consumeraffairs.com/homeowners/thermador.html
Mar 30, 2017 | Thermador RDF30 Dual Fuel (Electric and...
Thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Kitchen Ranges Logo
531 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
