Question about Epson Aculaser C1100 Printer
Cyan toner problem
Dear Sirs:
I just changed the Cyan toner on my Epson c1100 but it did not correct the problem. There is a section of about 2cm wide that will not print cyan. The other three colors print fine. I have confirmed this by making four lines (KYMC) across the page and seeing all print perfect except for one section of the Cyan.
Can anyone help?!
Thanks! Andy
  • B4Z4 Mar 19, 2009
    Hi, I have a similar problem, a light green logo will not print on the right hand side of the page. When I magnify the logo so that it prints accross all of the page it starts fine on the left but gradually gets more white streaks until nothing is printed in the particular shade of green. Any ideas? Regards Barry
  • 163 Answers
Is the section that is not printing down the r/h side of the page?
If so then it is likely that one of your toners is not "locked" in fully. Open the top panel, lift up the orange lever and pull out the PCU. You can now rotate the cartridges, check each one is fully locked in by the coloured levers on the r/h side. Even if one is slightly raised it will block the path of the laser and cause the symptoms that you describe.
Please take a moment to rate this solution. Thanks.
Posted on Mar 08, 2009
My Epson Aculaser C1100 shows 'change toner K'
I've just replaced the the Yellow and Magenta colour toner based on your fantastic advice...
gbdmequick
Jul 17, 2012 | Epson Aculaser C1100 Printer
How exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
May 15, 2010 | Epson Aculaser C1100 Printer
Epson acculaser c1100 ink replacement
K- black
M- Magenta (red)
Y- Yellow
C- Cyan (blue)
Hope this helps.
Jul 03, 2009 | Epson Aculaser C1100 Printer
Changing a cartridge C1100
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate Toner it will rotate to offer the correct toner. Open up the front cover, reach inside and change the position of the coloured part of the cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out first. Put the new toner in and turn the coloured part to the locked symbol.
Please take a moment to rate this solution, thanks.
Mar 24, 2009 | Epson Aculaser C1100 Printer
Toner needs black toner how do i replace just the black toner
You shoulh have a button to rotate the carousel, or unplug the power cord and try again.
Mar 03, 2009 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
Oct 28, 2008 | Epson Aculaser C1100 Printer
Toners c1100 epson
Yes this one is a pain.
Then within that menu keep going through the (many) options till you get to
or 'Change Toner C' (if it is Cyan)
etcetera.
Once you select the appropriate 'Change Toner' it will rotate to offer the correct toner. Open up the lid at the front (the word Epson is on it). Reach inside and change the position of the coloured part of the toner cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out slightly in front of the other side.
Then put the new toner cartridge in and turn the coloured part to the locked symbol and close up.
The same process will allow you to move any of the toners in and out.
Cheers
Jul 04, 2008 | Epson Aculaser C1100 Printer
K toner low
C - is for Cyan
M - is for Magenta
Y - is for Yellow
K - is for BlacK
Jan 25, 2008 | Epson Aculaser C1100 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Aculaser C1900
Sounds like you have a spot of toner on the laser lens. Pull out the waste toner bottle and toward the left of center you will see a little handle sticking out. This is the cleaner pads that wipes the lens. Pull it in and out a few times. Put the waste bottle back in and print a page or two. you should find your good as new again.
Sep 07, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
120 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
