Question about Maytag MDE7600AY Electric Dryer
Loose and broken baffle
One of the baffles in my MDE7600 electric Maytag dryer is loose (actually one side came off). How do I fix it?
    Problem Solver:
  • 9 Answers
D
Take off 4 door screws 2 right 2 left remove door pull front forward them two screws 5/16 in front with two brackets that hold top down. thats it just rotate drum and tighten or replace fin . ten minutes tops is all it takes.
my fin broke the screw holes so i will try longer screws if not i will leave off and run with two.
Posted on Oct 03, 2012
4 Suggested Answers
iwillfixforu
  • 619 Answers
SOURCE: Need to repair loose Baffle on Maytag Electric Dryer MDE7675AYW
On this model you will see 4 phillips screws in the recessed area when the door is open. 2 on each side. Take the 2 on the right out and then the 2 holding the hinges to the cabinet. Remove the door and then pull the front panel off by pulling toward you. Then you will see 2 screws holding the top down. 1 on each side near the top. Remove these and the top will lift back resting against the wall. From here you can get to the baffles. Good luck and thanks, Rick
Posted on Feb 28, 2010
  • 311 Answers
SOURCE: short baffle is loose
You can pop the top with a drywall putty knife there is two tabs on each side. This will allow you to access the drum. Then tighten the screws holding the baffle in place.
Posted on Jan 22, 2010
mc1bean
  • 3053 Answers
SOURCE: loose baffle in my Maytag Neptune MDE5500AY electric dryer
Hello, sheila I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
How to fix a drum baffel screw on a maytag dryer
This is an easy fix. You need to pop the top of the dryer up to do so. Depending on the model you may have to take the front off (older models), or just locate the clips located on the left and right side under the lid, and with a flat head screw driver push them in and lift up. (newer models). After you have the top up, located the baffle thats broken and install. Keep in mind that if the baffle is loose its more than like the hole where the screw goes is stripped and the whole baffle should be changed.
Apr 25, 2012 | Maytag Dryers
Maytag neptune dryer one of the dividers the screws came loose how can I fix this without calling for service
You are probably referring to the drum baffles. The baffles securing screws can be retightened by raising the top which requires the removal of the front panel. Click on the link below for the detailed steps.
Retightening the Baffle Screws on Maytag Neptune Dryers
Jan 24, 2011 | Dryers
Feb 28, 2010 | Dryers
Short baffle is loose
Jan 22, 2010 | Maytag Dryers
Baffle loose (Can see hole when moving baffle)
Hi there :)
The baffles are held in by 2 quarter inch screws per baffle. The only way to get to them is by taking off the top lid of the dryer.
Good luck.
Aug 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
Dryer Baffle Coming Loose
See if there are 2 screws located at the bottom front of dryer,unscrew anft panel up untilthe clips that are at the top disengage, disconnect door switch and any other connections , taking note of the connections.
W
Jan 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Fix Loose Baffles
The two screws that hold the door door hinges and the two on the opposite side of the door opening hold the front panel in place. Once you remove the door and the other two screws the front panel should swing down to access the screws that hold down the top. But you may be able to reach the baffle screws once the front cover is removed.
Oct 30, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
124 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
