Question about Microsoft Windows Vista Ultimate Edition
Problem with instaling windows xp
I can't install windows xp in my system . When booting ,after loading files system stops with blue screen message
  • 21 Answers
I got your problem hunny, for properly installation u have to first format the windows and shut down the computer take a new cd of windows check your CD ROM is OK or Not then Install the windows if any new hardware u attached before pull out that and install the windows may God your problem will be solved if got your solution plz reply me .
Posted on Mar 07, 2009
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Dell latitude e4200 restarts with blue screen
Sounds like the image doesn't have the right drive controller driver included. Could be because the image was created on a different laptop or could be the drive controller is configured differently. You can confirm this from the STOP error code on the blue screen
Go into the BIOS setup (probably F2 at boot) and see if the controller mode is set to AHCI. If so, set it to compatibility or combined(?) and try again.
Either way, if you've installed an image for the wrong hardware, you probably should do a remedial install. Boot from your Windows XP disc and follow the prompts as if you were doing a clean install until you get to the license agreement. At the next screen, it should show you any existing Windows installs and give you a new option to repair. Let this go - it won't touch any user files, just replace all the Windows files with those from the CD. Have your system drivers and service packs handy to tidy up when it's done.
Apr 10, 2012 | Dell Latitude E4200 Notebook
After installing some recent windows updates, I then did a restart to the computer. The computer no longer will boot into windows. It ' boots to windows xp logo and then changes to a blue screen after...
This may help.
http://www.user-guides.co.uk/cddownload/Samsung/N120-12GBK/Samsung-N120-12GBK-Fix-Repair-NTLDR-Missing-Corrupt-or-Compressed-Boot-Disk-CD-98-XP-2000-502214.html
I have never used one as I have my own boot disc.
Feb 15, 2011 | Samsung N120-12GBK Netbook
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Sep 27, 2010 | Microsoft Windows XP Home Edition
Hi, My laptop Dell Inspiron 6000 have a blue screen every time it boots up. Can't load Windows (XP Home) the error message is: *** STOP 0x00190203, 0x86D63828, 0xC0000102, 0x00000000) Anyone can help?
there must have been a problem with the drivers you have just installed, or there is a corrupt windows file on your system, you should try reinstalling the system without reformating it with the use of a Bootable Windows XP Home Disk, you should make your CD/DVD Drive to boot from your system by configuring your bios on your boot priority.
When you are on the WIndows XP setup screen press enter, accept the license agreement, and it will check if you have existing windows partiotion, press R to repair the Partition, wait for it to finish, then your system comes back to normal.
Or another way is to boot into Safe Mode, in order to check if there are driver conflicts or corrupted files on your Windows system. Press F8 to go a menu where you can select to boot from Safe Mode.
Jan 06, 2010 | Computers & Internet
Stop:0x0000007B tried to boot in all modes..we go to blue screen with stop: cannot get a command prompt either
Issue : Blue screen with Error0x0000007B
Solution
I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
The above error comes if the boot volume is corrupted and cannot be initiated by Windows XP. or You are installing Windows XP on a mirrored boot partition that was created by Microsoft Windows NT 4.0.
To completely resolve your issue i think you have to reinstall the OS.
Have to format the Hard drive
requirement
the OS - XP Home / Premium Installation CD
Disk formatting is the initial part of the process for preparing a hard disk or other storage medium for its first use. The disk formatting includes setting up an empty file system. A disk formatting may setup multiple file systems by formatting partitions for each file system.
Check this following Video Link
Help you with uninstall and reinstall the XP
Jan 03, 2010 | Dell Microsoft Windows XP Home Edition
I recently tried to install a new WD320Gb HD and windows XP won't load. I loaded it to the drive from another computer and Windows won't successfully boot up. I get a Stop: 0x0000076B (0xF7946640,...
You installed the 320GB drive into another system & installed windows XP. Than removed the drive & installed it into another computer!
All of windows internal drivers for the first install will not function in the second. (Windows XP is going nuts).
You have to do a fresh install while in the system you want to keep the drive in. This is why your getting the stop errors & blue screens.
You must have a reason of why you did not install the 320GB drive into the second computer for the XP installation?
Care to provide the why?
Mike
Apr 26, 2009 | Biostar M7NCD Pro Motherboard
Problem with installing xp
after completion you set the bios to defaults and reboot the system later you remove the cd
try this
Mar 07, 2009 | Microsoft Windows XP Professional With...
BLUE SCREEN W/ MESSAGE STOP: C000007B BAD IMAGE.
Try to look for your windows xp cd.
Turn the computer off. Restart it and start tapping f12 right after.
Insert the cd. Choose the option that says CD/CDRW/DVDRW from the screen and press enter. Watch out for a prompt that will say 'Press any key to boot from cd'. press any key as soon as you get this. If you miss it, you'll get the error again. You should get the blue windows setup screen if you caught it at the right time.
Wait until you get the 'welcome to setup' screen.
Press R.
Follow any other instructions that you may get until it gives you the C:\> prompt.
Type in bootcfg /rebuild.
Below is a listing of the common steps you are likely going to encounter.
* Prompt for the identified versions of Windows installed. When you receive this prompt press Y if the bootcfg command properly identified each of the Windows operating systems installed on the computer. It is important to realize this command will only detect Windows XP, Windows 2000, and Windows NT installations.
* Prompt to enter the load identifier. This is the name of the operating system for the boot.ini. For example, Microsoft Windows XP Home users would enter "Microsoft Windows XP Home edition". If you have Windowx XP pro edition, enter 'Microsoft Windows XP Professional'
* Prompt to Enter OS load options. When this prompt is received type /fastdetect to automatically detect the available options.
Then type 'exit'. and let the computer reboot. If you get two options for microsoft windows. Choose the one that says what you entered when you were in the recovery console.
If you are able to boot correctly after those steps, go to start>click run. Then type msconfig. Click ok. Click the boot.ini tab. Click 'check all boot paths'. Click ok or yes. click close and restart if prompted. You shouldn't get the prompt for two microsoft windows anymore.
Jan 02, 2009 | Dell Inspiron 1300 Notebook
Microsoft Windows Vista Ultimate Edition Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
