Question about Microsoft Windows Vista Ultimate Edition
For themes in xp it is .themes file but not .desktop files then how to run .desktop files
How to instal  s/w & themes in multimidia mobile
Posted on Mar 07, 2009
Where can i download themes for windows xp professional for free?
Good Day User,
This link may help you for the themes you are looking for. Enjoy. http://en.softonic.com/s/free-style-xp-themes
Thank you!
Apr 17, 2011 | Microsoft Windows XP Professional
Tip
Changing themes on Windows XP.
So, here we have a simple guide on how to change your normal windows look and how to install a custom theme which you will find many online.
Here is our original windows xp themed start menu and desktop.
First to install a new theme you first have to obtain one, here are a few
After you have downloaded the zip file containing the theme. Double click on the file to open it.
Now, this may look different on your pc, it depends if you have installed a program to extract zip files. If you are familiar with zip files etc just extract the files and run the setup to install the theme.
Inside the zip file you will find the following
Double click on the setup file to install the theme.
you may get a pop-up asking for you to extract all, run or cancel, click on run if you do. if asked again, click run again.
Basically install the theme just by clicking next next next and finally finish.
Once you have installed the theme, right click on your desktop background and select properties.
On the properties / theme page, click open the list of themes and select Royale from the list, then apply and OK.
And here is the new theme we downloaded:
You can obtain different themes from all over the net, I would suggest you go with the site linked here, scan the files for viruses before installing. Good luck and thanks for reading.
on Jan 23, 2010 | Computers & Internet
I was able to download this zip file about a xp theme and i was able to unzip it already, but there's no executable file to istall my new theme. please help me.. thanks,...
Prepare Your Computer
  1. Because Micro$oft wants you buy everything from them, Windows XP wants theme files to be digitally signed. If they aren't then XP won't let you use the themes. You must first patch your uxthemes.dll file in your C:\Windows\System32 directory. This can be easily done using the Uxthemes Patch which you can download here. The patch supports Windows XP, SP1, SP2, XP 64 bit and Windows Server 2003. Run the patch, it will "fix" your uxtheme.dll file so you can use 3rd party visual styles. Disregard any warnings about files being changed, that is what we want to do. After you run the patch reboot your computer. Note: We recommend you create a restore point before running the patch just for good measure. We did not author this file we have used it our selves with no problems, use it at your own risk.
Install the XP Theme Files
  1. Themes are usually downloaded as a .zip file which must first be scanned using a virus scanning program, then unzipped to a temporary folder you can create on your desktop. Inside that folder you will most likely find a wallpaper image, .msstyles file, a .theme file and possibly a font file. it all depends on what the author has chosen to include in their theme package.
  2. If your theme package contains one or more font files (.ttf) copy them to your C:\Windows\Fonts\ folder.
  3. You may also find one or more .theme files (like axis.theme. Copy it/them to your C:\Windows\Resources\Themes\ folder. You will see a folder called Luna already in there, leave that alone, it is your existing Micro$oft XP Theme.
  4. Locate the .msstyles file, create a folder in the C:\Windows\Resources\Themes\ folder, I usually name it what the .msstyles file is named (like axis.msstyles so the folder would be axis).
  5. If you find a file called ShellStyle.dll, create a folder called Shell inside the first folder you created. Create another folder inside that called NormalColor. Copy ShellStyle.dll into the NormalColor folder.
  6. Most of the time you will unzip the file and everything will be properly ordered and only need to be copied to your C:\Windows\Resources\Themes\ folder.
  7. To install the wallpaper copy the wallpaper image file to your My Pictures folder.
How to Use the XP Theme
  1. While in your My Pictures folder that contains your wallpaper, click on the wallpaper file once to highlight it. In the menu on the left side of the window you will see at the top Picture Tasks. Click on Set as desktop background. You should see the wallpaper on your desktop.
  2. If the wallpaper needs to be stretched to fill the screen close the My Pictures window. Right click on the desktop, select Properties. The Display Properties window comes up, choose the Desktop tab. Your wallpaper should be highlighted in the list, using the Position box choose if you want it Tiled, Centered or Stretched.
  3. While in Display Properties if your theme had a .theme file select the Themes tab and select your theme from the list. If your theme only had a .msstyles file go to the Appearance tab and select your theme from the Windows and Buttons list.
  4. After you are done making your choices you can go to the Themes tab and save your theme by clicking Save As..., and then name it something.
  5. That's all there is to it and all without buying any programs.
Aug 17, 2010 | Computers & Internet
My desktop become balk its not setting any theme more than one minute.
To restore the ability to change the desktop Wallpaper in your system, download the file wallpaper_enable.reg for Windows 2000/XP/Vista systems, and save the file to your Desktop. Right-click wallpaper_enable.reg and choose Merge to apply the settings.
Jul 16, 2010 | Microsoft Windows XP Professional
I have Windows XP. I want to download some new icons and cursors to my pc. I know to Save As, but where I save them?
This is normally called a theme for XP.
Most websites providing themes have a set of instructions for each particular theme. You should just follow those instructions step by step.
If the theme is an EXE file, you should just be able to click on it, or when the download screen comes on, choose RUN instead of save.
Feb 28, 2010 | Computers & Internet
Vista skin download websites.
Hi Bhupendra,
You can download Vista skins for XP from:
http://www.crystalxp.net/galerie/en.id.130.htm
The installation is easy, just extract the Zip file by right-clicking it and selecting extract here, run the installer and select the features you want to install.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Sep 14, 2009 | Microsoft Windows Vista Ultimate Edition
I need new themes for windows xp..i don't know how to apply the theme that i download from the net. how to apply it???? i need to know!:))
G:\WINDOWS\Resources\Themes
download the theme files and paste in above folder...then right click on the desktop and on theme tab u can change the theme..
Feb 20, 2009 | Microsoft Windows XP Professional With...
Free download vista themes for xp
just download and install whatever themes u want in desktop,
and copy the theme files into c:\windows\resources\themes
and u find ur themes in process
Jul 05, 2008 | Microsoft Windows Vista Ultimate Edition
Themes continued..
Download and use a program called styleXP from here, it's your last solution : http://www.tgtsoft.com/download.php
Aug 24, 2007 | Microsoft Windows XP Professional With...
XP Themes
i wanna full version themes for my desktops
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
